Message 1 of 13
Setting up Mac for BT and old Talktalk mail
We changed from talktalk to BT today and I want to set up Mac mail to receive both my mail from my old provider talktalk and also a new bt email address which I set up this morning (and hasn't yet worked....)
As I need to receive mail from my old talktalk.net address until everyone has the new BT mail, I need both accounts on my mac mail.  I am able to receive mail on my talktalk address but cannot send using this address/server, it says "cannot send mail using the server talktalk".  It won't connect using the bt server either?
Can anyone let me know how I receive emails from both, but send using BT and why this isn't working for me (unable to send mail).
I'm aware I may sound like a complete techno idiot here, but hoping its a simple fix!
Many thanks
12 REPLIES 12
Message 2 of 13
Re: Setting up Mac for BT and old Talktalk mail
Presumably as you are no longer with Talk Talk, you no longer have an account on their outgoing mail server. You need to send via the BT SMTP mail server but you need a BTinternet address to authenticate with. I am not familiar with Mac Mail so don't know the details of how to accomplish that but you need to configure the outgoing server with the following details.
Server mail.btinternet.com
Port 465
SSL Yes
User name your full xxxx@btinternet.com email address
Password your Btinternet.com password
Authenticate plain password
The BT account will be the same details as above for outgoing, for incoming use port 993 and SSL for IMAP or 995 and SSL for POP3.
Message 3 of 13
Thank you for replying.  Will this work today with all the email issues or should I leave until tomorrow?  I still can't log onto my email through the internet either which suggests I still have a problem?
L
Message 4 of 13
It might be wise to leave it until tomorrow, certainly until you can access your email via webmail . If you try setting it up now and have problems, you will be unsure of the cause.
Expert
Message 5 of 13
In Mac Mail if you go to Mail >Preferences >Accounts, click + at the bottom and then 'Add Other Mail Account' and Continue. Enter your Name, email address and password as supplied by BT. Then click Create. This should automatically fill in all the details, ports etc. It will be an IMAP account as that's the default. If you want POP then hold the alt key and the Create button will change to Next. You'll then have to fill in the details listed above yourself.
Message 6 of 13
I wouldn't let it automatically fill in the details, I think that is where most problems stem from. It is better to set the account up manually
Message 7 of 13
I wouldn't know how to? Can I check the details it has filled in and what should they say?
Message 8 of 13
BT didn't supply an email address, I tried to do that this morning, but as yet haven't been able to get it working?!
Message 9 of 13
When you add the account there should be an option to enter the details manually. The details are those I posted earlier.
Message 10 of 13
Have a look at this link for setting up a BT email address.
http://bt.custhelp.com/app/answers/detail/a_id/44888/c/346
Once you have set it up and you are sure it is working OK then set it up on your Mac.
