Message 1 of 8
Settings For Netgear Connection to ONT What do i enter in my netgear router
Is their any settings I need for my netgear to connect to the ont or should it just recognize that there is a connection or do i need to enter my bt username and password that I use for the web site somewhere in my router.
7 REPLIES 7
Message 2 of 8
Re: Settings For Netgear Connection to ONT What do i enter in my netgear router
need username and password
[email protected]  with password anything usually just BT
Message 3 of 8
@imjolly Im on Ultra fast Fiber not FFTC im on the brand new fiber to the home wishing to connect my netgear nighthawk
Message 4 of 8
Still the same username and password.
Message 5 of 8
Message 6 of 8
Im not over Dam Coper !!!!!! im on Ultra Fast FTTH
Message 7 of 8
the username and password (if needed) are the same for ALL BT broadband packages
I don't know how many times it needs to be repeated
Message 8 of 8
It doesn't matter if you are over wet string, the username and password are the same for the umpteenth time.
