Message 1 of 2
Setup smart hub2 but phones do not work
Hi,
I have just setup the smart hub2 router for my dad (moved from Sky). They have a wired  landline phones in one of the rooms and a set of 3 cordless phones in other rooms. The wired landline phone cable and the base unit for the cordless need to be plugged into the router but there is only space for one phone line in the router and the wired landline phone in another room and therefore would require a long cable. Does any one have any suggestions as parents have been with one phone in one of the rooms as the base unit is playing up from the cordless phones.
1 REPLY 1
Message 2 of 2
Re: Setup smart hub2 but phones do not work
you can phone 150 and request an adapter for DV which connects to hub bu just plugging into power socket and pairing with hub.  you can then connect your other existing old style phone
other options are posted here which may help   https://community.bt.com/t5/Home-phone-including-Digital/Confusion-Digital-Voice-and-Old-Phones/td-p...
