Message 1 of 5
Severe game rubber banding, degraded connection to Warzone / Battlefield game servers. Surrey/London
Had the issue once a month or so ago, and now have had it 4 times in the span of a week, sometimes its all day so I just give up, sometimes like today it was fine mid day, and now completely unplayable in the evening.
Perfect download speeds every single time, low ms, low jitter, 0 packet loss, port forwarding set up properly etc etc - basically its not me. Until I try and play Warzone / Battlefield 2042 whereupon the route the data packets are taking from Surrey are hitting a degraded hop causing extreme packet loss and unplayable rubber banding.
The game servers are probably london based.
4 REPLIES 4
Message 2 of 5
Re: Severe game rubber banding, degraded connection to Warzone / Battlefield game servers. Surrey/Lo
Firstly make sure you are using a wired connection and not WiFi. Secondly if you aren't an expert at routing to fast game servers yourself then it will help if you got a gaming router as they have tools for selecting not only the nearest gaming server but also the quickest and best quality.
Message 3 of 5
I don't need a basics of networking class, or to be told to buy a useless gimmick gaming router, what I need is BT to fix whatever degraded exchange they have near London.
Message 4 of 5
Wow, bit rude. You haven't even proved there's a BT issue in your post. Is the issue happening on both a wired & wireless connection for example?
Message 5 of 5
How have you identified that it’s a peering issue?
Probably or maybe a London based server is probably wrong as the game can throw you all over the place.
Explain in detail how you are testing your network to come to your conclusions.
