Message 1 of 6
Shetland - loss of Broadband
Hi all
Barely able to log in here - been a while since I needed too
Anyway - seems like something big has happened to a lot of peoples connects today/tonight - lot of folk I know (with BT and with other providers are either very slow or cut off completely)
Thing is - I went to the "check your phone line" section and put in my number and it says everything is fine - no problems - your exchange is tippity top
Well on other forums there is talk of major damage to a undersea cable
So can anyone on here find out which one is correct and give me/us some sort of idea as what is wrong and when it will be likely fixed
Cheers
John
(and yes - done all the checks I can - but the speed test won't run - it times out)
5 REPLIES 5
Message 2 of 6
Re: Shetland - loss of Broadband
this link shows problems http://btbusiness.custhelp.com/app/service_status/
it does appear there is a undersea fibre cable fault which is being worked on at this time no time scale to fix is known
Message 3 of 6
Yeah -other reports coming in say the same - fibre fault near Orkney
Only just able to log in now - running at about 0.28 kbps
Thanks for info - will see how it goes I guess - least we still have the phone - loads of folk I know have lost that as well!
Message 4 of 6
I have sent you a PM
Message 5 of 6
Thanks John - how do you access PM's?
Message 6 of 6
click on the little envelope on the forum log in page
