Message 1 of 11
Shocking broadband
been with bt many years no problems up until last few weeks. Speed is up and down constantly dropping below 20 a lot. Phoned bt was told was being looked into. Got a text to say we are looking into your broadband speed and need 2 more days this was on the 25th of June and someone would be in touch. Still not sorted and no contact or explanation to whats going on. I need out of this contract
10 REPLIES 10
Message 2 of 11
Re: Shocking broadband
Was it on all of them or just the one?
Message 3 of 11
All of what or just the one (of what)?
Message 4 of 11
someone made the most of the pubs reopening
Message 5 of 11
in order for the forum members to help please can you post the stats from your router (if hub enter 192.168.1.254 in your browser) and if  HH5 then go to troubleshooting then helpdesk and if HH6/SH2 then advanced settings then technical log information .
Have you tried the quiet line test? - dial 17070 option 2 - should hear nothing - best done with a corded phone. if cordless phone you may hear a 'dull hum' which is normal
enter your phone number and post results  remember to delete number   https://www.broadbandchecker.btwholesale.com/#/ADSL
Someone may then be able to offer help/assistance/suggestions to your problem
Message 6 of 11
Shocking broadband.
I will swap you for my shocking broadband. 🙄
___________________________________________________________________________________________
Say thanks by clicking the Thumbs Up icon. Have I resolved your issue? Click "Mark As Accepted Solution"
Message 7 of 11
Ok got me there that is ridiculous. Hope your not paying for that
Message 8 of 11
@imjolly
Hope this helps
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream HandbackThreshold(Mbps) WBC FTTC Availability Date WBC SOGEA Availability Date Left in JumperHigh Low High Low        VDSL Range A (Clean)
VDSL Range B (Impacted)
52.13511.67.230AvailableAvailable--
50.530.711.46.625AvailableAvailable--
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream Range (Mbps) Availability Date FTTP Install ProcessFTTP on Demand
33030--Available--
ADSL Products Downstream Line Rate (Mbps) Upstream Line Rate (Mbps) Downstream Range(Mbps) ADSL Availability Date WBC SOADSL Availability Date Left in JumperWBC ADSL 2+WBC ADSL2+ Annex MADSL MaxWBC Fixed RateFixed Rate
Up to 14--12 to 16AvailableAvailable--
Up to 14Up to 112 to 16AvailableAvailable--
Up to 6--5 to 8AvailableAvailable--
2----AvailableAvailable--
2----Available----
Observed Speeds VDSLMax Observed Downstream SpeedMax Observed Upstream SpeedObserved Date
47.2
7.92
2020-06-30
Other Offerings Availability DateVDSL MulticastADSL Multicast
Available
Available
Premise Environment StatusBridge TapVRINTE FacePlateLast Test Date
N
N
N
15-06-2020
Message 9 of 11
Probably pay more than you a month.
Never been so bad and disconnects at least 10 times a day. 😬
Any walls around I can bang my head on.☹️
Message 10 of 11
Ha, sorry. Wasn’t meant to reply to you.
