Message 1 of 10
Should I book engineer?
Hi
I have been getting disconnections. At first it wasn't that bad as it used to drop once every few weeks but recently it been getting worse as it drops per few days. The error log shows ppp0 LCP down and ppp0 sent [LCP TermReq id=0x2 "User request"]
It seems to cut out randomly and it would drop back my speed.
My router is TP-LINK VDSL 2 however I have also tried homehub 5 and I get same problem so I know it not the router. Homehub 5 also shows similar error log.
Should I book an engineer?
Thanks.
9 REPLIES 9
Moderator
Moderator
Message 2 of 10
Re: Should I book engineer?
Hi jonty789,
Thanks for posting. Sorry you’re having problems. Can you try running the speed test, including the further diagnostics, and post the results. That will let us see how the connection is performing and if there are any problems we’ll be happy to help.
Cheers
David
Message 3 of 10
I am sick of this rubbish. I phoned bt support 5 times and none of them help me. Every of them saying different things and I am now getting fed up. I am having connection drop problems. I have checked my equipments and even tried different router but still getting drops out. I can do speed test if you want but it won't show any connections drops in the results.
Distinguished Guru
Message 4 of 10
Can you post your line stats from the HH5 please? These are in Troubleshooting/Helpdesk on the web interface at http://192.168.1.254
Lines 1-13 will be enough
If not, I'll try again 🙂
Message 5 of 10
Hi i just plug in home hub 5 to get stats. Thanks
1. Product name:BT Home Hub
2. Serial number:
3. Firmware version:Software version 4.7.5.1.83.8.173.1.6 (Type A) Last updated 09/05/14
4. Board version:BT Hub 5A
5. VDSL uptime:0 days, 00:00:41
6. Data rate:11795 / 48176
7. Maximum data rate:11799 / 55880
8. Noise margin:6.0 / 6.6
9. Line attenuation:0.0 / 20.1
10. Signal attenuation:0.0 / 19.7
11. Data sent/received:0.0 MB / 0.0 MB
12. Broadband username:bthomehub@btbroadband.com
Distinguished Guru
Message 6 of 10
What is the estimate for your line given by www.dslchecker.bt.com ?
please quote both the FTTC Range A and FTTC Range B speeds
Message 7 of 10
have you taken up Davids offer of help
Message 8 of 10
Yep sorry I have. I just waiting to hear back if he still want speedtest results cos I can't see anything in speedtest results which would shows connection drops. I will post both results now.
http://i.imgur.com/RD7RTbV.png
http://i.imgur.com/5iIwBjF.png
(uploaded to imgur for bigger size)
Thank you so much for having a look into this
Distinguished Guru
Message 9 of 10
Well, your speed is a little low for the attenuation, but the range of estimated speeds is so wide that it's impossible to draw any conclusion at all from your line stats.
Message 10 of 10
Hm ok thanks. I think I will probably contact BT care twitter. Thanks
