Hey guys, should my ping be this high?
http://www.speedtest.net/result/2030212356.png
It can go up to as much as 38 to maybe 42ms sometimes, particularly in the evenings.
Thoughts?
Here they are 🙂
Ping has started…
PING www.bbc.net.uk (212.58.244.66): 56 data bytes
64 bytes from 212.58.244.66: icmp_seq=0 ttl=50 time=26.909 ms
64 bytes from 212.58.244.66: icmp_seq=1 ttl=50 time=30.388 ms
64 bytes from 212.58.244.66: icmp_seq=2 ttl=50 time=29.512 ms
64 bytes from 212.58.244.66: icmp_seq=3 ttl=50 time=26.104 ms
--- www.bbc.net.uk ping statistics ---
4 packets transmitted, 4 packets received, 0.0% packet loss
round-trip min/avg/max/stddev = 26.104/28.228/30.388/1.772 ms
MadGamer1988,
Those ping are not too bad as the 28ms average is to and from the server,so your one way ping is about 14ms average.
For gaming,as long as you have a stable connection and do not get discoed it looks fine.
But I quess a ping below 15ms would be better.
It can also depend on distance to the server [game server] as about 104ms round trip to a US server would be ok as long as you stay connected.
I run game servers and some of the guys joining it sometimes show pings of about 150ms but as others on the server can also get quite high pings,it evens it`s self out as long as they all stay connected.
Obviously ping is important,but packet loss is what you don`t want.And you are not losing packets.
I guess mileage may vary. My pings are pretty low by comparison.
I'm Wired to my HomeHub not Wireless BTW.
C:\Users\graeme>ping www.bbc.co.uk
Pinging www.bbc.net.uk [212.58.246.94] with 32 bytes of data:
Reply from 212.58.246.94: bytes=32 time=11ms TTL=51
Reply from 212.58.246.94: bytes=32 time=10ms TTL=51
Ping statistics for 212.58.246.94:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 10ms, Maximum = 11ms, Average = 10ms
Here's a Trace Route as well :
C:\Users\graeme>tracert www.bbc.co.uk
Tracing route to www.bbc.net.uk [212.58.246.91]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms BTHomeHub.<snip> [192.168.0.2]
2 6 ms 5 ms 5 ms 217.32.147.3
3 7 ms 7 ms 7 ms 217.32.147.46
4 9 ms 8 ms 8 ms 213.120.177.74
5 9 ms 8 ms 8 ms 217.41.168.227
6 8 ms 8 ms 8 ms 217.41.168.109
7 9 ms 8 ms 8 ms 109.159.249.240
8 12 ms 15 ms 15 ms core1-te0-15-0-17.faraday.ukcore.bt.net [109.159.249.159]
9 9 ms 9 ms 9 ms peer2-xe8-0-0.telehouse.ukcore.bt.net [109.159.254.177]
10 9 ms 9 ms 9 ms 194.74.65.42
11 * * * Request timed out.
12 10 ms 11 ms 10 ms ae0.er01.cwwtf.bbc.co.uk [132.185.254.93]
13 12 ms 12 ms 12 ms 132.185.255.165
14 10 ms 10 ms 10 ms bbc-vip012.cwwtf.bbc.co.uk [212.58.246.91]
Trace complete.
