Expert
Message 31 of 40
Re: Sick of BT's constant lies!!!
Yes SIR!!!. Mr. gg30340. Will get on it first thing, that should sort my issues out!.
Please click on white star to the left and say thanks if I have helped you at all!. 🙂 Thank you. Some handy links Copy & Paste:-
http://bthomehub.home/
http://netalyzr.icsi.berkeley.edu/index.html
http://diagnostics.bt.com/login/?workflow=Speed
Message 32 of 40
Do I detect a touch of sarcasm. Either way, suit your self what ever you, I give up!
Recognised Expert
Message 33 of 40
Quoted from MBR123,
"I am paying for option 2 not 1, dont know what is going on with the 40/10 thing"
The reason you are getting the 40/10 result in your diagnostic report is because even though you state you are on an 80/20 package you have somhow been put onto a 40/10 package in error.
So there are only 2 ways to solve this.
1)Ring the sales options section and try to have your payments reduced to that package.
2)If you are sure that your line can support it try to get your profile increased into the 80/20 bracket,but judging by your reports your line does not seem capable of supporting Infinity 2 80/20.
In effect you should not have been charged for 80/20 in the first place if your line has never been fast enough to support it.
Has your upload profile ever shown as a 20Mbps profile,?, if not then it has always been at 10Mbps.
Expert
Message 34 of 40
I think you will find no mistake has been made this seems to be ISP practice. If wholesale estimate you getting 35mbps they will put you on 40mbps even though you request 80mbps (after all it is an estimate atleast thats what bt told me when speeds where low!) to get the fastest speed but the ISP will just put you on a package that they deem as being full speed. A hacked modem shows all! Had to give my ISP a talking to for this practice,they did then put me on the package that i was paying for in the first place! I don't think you will get much help from india though, just glad my ISP and support are in the UK 5min phone call switched profile 24hours later 😉
Recognised Expert
Message 35 of 40
I agree Enigma123,but in this case it looks like the line has never been capable of supporting Infinity 2 80/20, so Inifinity 1 40/10 should have been installed and charged for at day one.
If the customer asked for the 80/20 package though I guess BT are going to install that package even knowing that it was not going to work at those speeds or anywhere near.
Message 36 of 40
If i remember correctly the older infinity contracts were
40 /10 40 gb usage limit 80/20 unlimited whereas the new contracts both have unlimited packages no ,therefore if on an older contract you would have had to sign up to the 80/20 speed to have obtained an unlimited package even if the line would not support it
Recognised Expert
Message 37 of 40
True John,I forgot that,in fact I never recontracted so even though I am on the 80/20 Unlimited package I am still throttled for P2P,but never use it.
And I was on the 40/10 Unlimited package up to April 2012,then it was ungraded free to 80/20 Unlimited under a new 18 month contract.
Message 38 of 40
Would the OP's IP profile not show that if he was on 80/20. The OP's profile is for Infinity 1.
Message 39 of 40
it should do but i cannot remember what happened back then there was also a 40/2mb service then
Expert
Message 40 of 40
I have had an idea, I am going to ask the nearest Openreach van near my area to do a DLM reset, see what he says, next time I see one close, which could be a while round here!. Its a plan? I will get on to the package change but I am a little bit worried of changing then being dropped to the estimates I am given now, cause of the history. But thanks for the replys everyone, good help here and yes I was been sarcy but I have was just having a bad day so dont take any notice. 😉
