Anonymous
Not applicable
Message 1 of 7
Signal Attenuation on router at 0
Stats:
Product Name: HomeHub4
2. Serial number: REDACTED
3. Firmware version: v0.07.04.01235-BT (Type B) Last updated [Unknown]
4. Board version: 01B
5. DSL uptime: 3 days, 17:45:05
6. Data Rate: 828 / 19805
7. Maximum Data Rate: 1412 / 21940
8. Noise Margin: 12.1 / 9.0
9. Line Attenuation: 5.2 / 7.5
10. Signal Attenuation: 0.0 / 11.9
11. Data sent/received: 4.6 GB / 145.4 GB
12. Broadband username: bthomehub@btbroadband.com
13. BT Wi-fi: No
14. 2.4GHz wireless network/SSID: REDACTED
15. 2.4GHz wireless connections: Enabled (802.11 b/g/n (up to 144 Mb/s))
16. 2.4GHz wireless security: WPA & WPA2 (Recommended)
17. 2.4GHz wireless channel: Automatic (Smart Wireless)
18. 5GHz wireless network/SSID: REDACTED
19. 5GHz wireless connections: Enabled (802.11 n (up to 300 Mb/s))
20. 5GHz wireless security: WPA2 Only
21. 5GHz wireless channel: Automatic (Smart Wireless)
22. Firewall: Default
23. MAC Address: REDACTED
24. VPI/VCI: 0/38
25. Modulation: G.992.5(ADSL2+)
26. Latency type: Interleaved
27. Software variant: -
28. Boot loader: 0.5.0-BT (Wed Nov 12 11:47:59 2014)
What is with these odd settings?
6 REPLIES 6
Anonymous
Not applicable
Message 2 of 7
Re: Signal Attenuation on router at 0
Can I also have interleaving turned off! Please!
Message 3 of 7
The signal problem is just a hub bug and not causing any problem
i think it was your previous resetting of the hub which resulted in latency changing from fast to interleaved but as you jot have 3 days stable the mods can help get you back to fast. Mods will post help here tomorrow
Moderator
Moderator
Message 4 of 7
@Anonymous Please use the 'click here to contact the mods' link in my forum profile to send in your details. You can find the link by clicking on my username.
Neil
Moderator
Moderator
Message 5 of 7
Hi @Anonymous I called earlier sorry I could not reach you. I just wanted to confirm that I have placed the order to remove Interleaving and this will complete in the next 24 hrs. Please check your connection and post back to confirm it has been completed after this.
Cheers
John
Anonymous
Not applicable
Message 6 of 7
Sorry, I wasn't free earlier when you called.
I can confirm that interleaving has been turned off. Thank you very much!
Moderator
Moderator
Message 7 of 7
Hi @Anonymous Thanks for posting back to confirm that the order has completed. I will now close this case.
cheers
John
