RickFraser
Newbie
Message 1 of 6
Signal loss on a routed BT path
Does anyone know WHO to report server problems to that are somewhere along an IP path to a destination?
I have a Vodafone Sure Signal box that connects to my BT Broadband and have had it since October 2010, and it's been great. But now it has stopped working, so I once again have no, or almost no, mobile phone signal at my location, being  a Vodafone dead spot.
I have reset everyrhing a great many times and followed all the troubleshooting guidelines but still no joy.
I have the SS1 type box attached to my BT Homehub, which tells me that the SS is connected fine. My internet connection is good and broadband is great. and the LAN connection to the SS shows a green light staedy, and the orange signal light pulsing.
If I pathping the Vodafone server, I get the following:-
pathping 212.183.133.181
Tracing route to host212-183-133-181.uk.access.vodafone.net [212.183.133.181]
over a maximum of 30 hops:
  0  starting point [xxx.xxx.x.xx]
  1  api.home [xxx.xxx.x.xxx]
  2  esr3.miltonkeynes3.broadband.bt.net [217.47.74.142]
  3  217.47.74.13
  4  213.1.69.26
  5  217.41.222.50
  6  217.41.222.182
  7  acc2-10GigE-0-0-0-4.bm.21cn-ipp.bt.net [109.159.248.194]
  8  core2-te0-13-0-4.ealing.ukcore.bt.net [109.159.248.138]
  9  peer1-xe10-1-0.telehouse.ukcore.bt.net [109.159.254.110]
 10  LNDGW2.arcor-ip.net [195.66.224.124]
 11  85.205.116.2
 12     *        *        *
Computing statistics for 300 seconds...
            Source to Here   This Node/Link
Hop  RTT    Lost/Sent = Pct  Lost/Sent = Pct  Address
                                0/ 100 =  0%   |
  1    0ms     0/ 100 =  0%     0/ 100 =  0%  api.home [xxx.xxx.x.xxx]
                                0/ 100 =  0%   |
  2   30ms     0/ 100 =  0%     0/ 100 =  0%  esr3.miltonkeynes3.broadband.bt.ne
t [217.47.74.142]
                                0/ 100 =  0%   |
  3   36ms     0/ 100 =  0%     0/ 100 =  0%  217.47.74.13
                                0/ 100 =  0%   |
  4   33ms     0/ 100 =  0%     0/ 100 =  0%  213.1.69.26
                                0/ 100 =  0%   |
  5  ---     100/ 100 =100%   100/ 100 =100%  217.41.222.50
                                0/ 100 =  0%   |
  6   34ms     0/ 100 =  0%     0/ 100 =  0%  217.41.222.182
                                0/ 100 =  0%   |
  7   34ms     0/ 100 =  0%     0/ 100 =  0%  acc2-10GigE-0-0-0-4.bm.21cn-ipp.bt
                                0/ 100 =  0%   |
  8   44ms     4/ 100 =  4%     4/ 100 =  4%  core2-te0-13-0-4.ealing.ukcore.bt.
                                0/ 100 =  0%   |
  9   42ms     7/ 100 =  7%     7/ 100 =  7%  peer1-xe10-1-0.telehouse.ukcore.bt
                                0/ 100 =  0%   |
 10   43ms     0/ 100 =  0%     0/ 100 =  0%  LNDGW2.arcor-ip.net [195.66.224.12
4]
                                0/ 100 =  0%   |
 11   39ms     0/ 100 =  0%     0/ 100 =  0%  85.205.116.2
                              100/ 100 =100%   |
 12  ---     100/ 100 =100%     0/ 100 =  0%  starting point [0.0.0.0]
Trace complete.
Seems I am losing 100% of the path on 217.41.222.50  - anyone know why it might no longer be working?
http://ip-lookup.net tells me that this server is located at the RIPE Network Coordination Centre in Amsterdam, but is netname BT-21CN-TMAN
Another day's try gives the same info, except I lose 100% at 217.41.222.58 instead of 217.41.222.50
How come I can ping both 217.41.222.50 and 217.41.222.58 IP addresses quite happily without problem? It only seems to be a problem trying to get to Vodafone server along the route?
Anyone able to help please?
5 REPLIES 5
Message 2 of 6
Re: Signal loss on a routed BT path
hi i suggest you contact vodafone it looks like a problem with them
RickFraser
Newbie
Message 3 of 6
Thanks John
Unfortunately, Vodafone say that as the signal is being lost on the route BEFORE it gets to their server, it is not their problem, but to contact my ISP.
Since my broadband connection is fine, BT say there is nothing they can do either.
I traced the signal failure to a BT server in Amsterdam, but have no way of knowing who I should be telling.
To my mind, it is STILL a Vodafone problem, as they sell the Sure Signal box as a fix to low signal areas by connecting to our own broadband. But they apparently think otherwise - not very good on the Customer Support side I think.
IanC
Recognised Expert
Message 4 of 6
The 100% packet loss only means that the node in question isn't responding itself.
If it were truly 100% packet loss at that hop, then you'd get no response from all subsequent hops.
Message 5 of 6
many nodes do not respond to pings for security reasons
RickFraser
Newbie
Message 6 of 6
Thank you John & Ian
Doesn't answer my question though. Since Vodafone say it is NOT their problem, and BT  say it's not theirs, WHO do I tell so something can be done????
