Message 1 of 19
Simple IP profile request, now wee bit confused, please help
Hi
Little background as to why i'm a bit confused 1st
While ago I was getting around 4000-4500kps connection speed using my HH2, then 1 day I had no BB light, phoned helpdesk and was advised my router was dead (no suprise as it was getting old), if i extended contract i could get the all singing and dancing HH3 free (not a prob, always had good service and little issues). Job done and just to wait for new hub, but after trying various other hubs to keep me online inc a borrowed HH3 it wasnt my router that was dead. Anyhow the fault at the exchange was sorted and life was good, till i started realising my downloads and streams were nowhere near as good as before.
Thought i'd request a IP profile reset after doing speedtest and seeing a low profile, but after reading various things I did a few tests and now am confused as to whether a IP profile would be worthless until im sure its all good my end 😕
I recieve lower connection speeds with HH3 and higher noise margin than I do using my HH2 (this is also my 2nd HH3 as 1st 1 liked to crash a lot)
Connections to front plate and test socket are very similar in reading, and this is the only thing plugged into my phone line through filter
Home Hub 2 stats
ADSL line status
Connection information
Line stateConnected
Connection time0 days, 0:32:43
Downstream2,976 Kbps
Upstream448 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
ModulationITU-T G.992.1
Latency typeInterleaved
Noise margin (Down/Up)11.6 dB / 14.0 dB
Line attenuation (Down/Up)55.0 dB / 31.5 dB
Output power (Down/Up)18.7 dBm / 12.3 dBm
Loss of Framing (Local)11
Loss of Signal (Local)1
Loss of Power (Local)0
FEC Errors (Down/Up)5951 / 0
CRC Errors (Down/Up)0 / N/A
HEC Errors (Down/Up)N/A / 0
Error Seconds (Local)
2
Home hub 3 stats (same location, wiring etc)
ADSL Line Status
Connection Information
Line state:Connected
Connection time:0 days, 00:06:30
Downstream:2.469 Mbps
Upstream:448 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.1 Annex A
Latency type:Interleaved
Noise margin (Down/Up):12.5 dB / 17.0 dB
Line attenuation (Down/Up):55.7 dB / 31.5 dB
Output power (Down/Up):18.7 dBm / 12.5 dBm
FEC Events (Down/Up):0 / 0
CRC Events (Down/Up):0 / 0
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):0 / 0
Error Seconds (Local/Remote):
61371 / 1340
Now previously the noise margin was 14+, but hey it was lower that time
This is the speedtest data from connection with the 'faster' HH2
1. Best Effort Test: -provides background information.
 Download  Speed
 1.8 Mbps
0 Mbps2 Mbps Max Achievable Speed
Download speed achieved during the test was - 1.8 Mbps
For your connection, the acceptable range of speeds is 0.4 Mbps-2 Mbps.
Additional Information:
Your DSL Connection Rate :2.98 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
IP Profile for your line is - 2 Mbps
Please help me get back to a better faster connection
ty
18 REPLIES 18
Message 2 of 19
Re: Simple IP profile request, now wee bit confused, please help
Have done a quiet line test and everything sounded ok
And how do i get a returns bag to send the broke HH3 bk as i never recieved 1
thx
Message 3 of 19
You must leave your home hub turned on and connected to your phone line for at least five days.
During that time, do not reset or disconnect it.
If your download speed has not increased after that time, then return to this thread for assistance.
Thank you
Message 4 of 19
Hi there, have left everything running without reconnection etc and my IP profile is now lower than before and max connect of 2mbs 😞
FAQ
 Download  Speed
 1.59 Mbps
Download speed achieved during the test was - 1.59 Mbps For your connection, the acceptable range of speeds  is 0.4 Mbps-2 Mbps. Additional Information: Your DSL Connection Rate :2.08 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM) IP Profile for your line is - 1.75 Mbps
ADSL Line Status
Connection time:5 days, 19:47:49
Downstream:2.031 Mbps
Upstream:448 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Noise margin (Down/Up):9.9 dB / 16.0 dB
Line attenuation (Down/Up):55.6 dB / 31.5 dB
Output power (Down/Up):18.7 dBm / 12.4 dBm
FEC Events (Down/Up):325497558 / 1732
CRC Events (Down/Up):151164 / 1811
HEC Events (Down/Up):344750 / 1160
Error Seconds (Local/Remote):47134 / 2206
Message 5 of 19
Hi your ip profile is correct for your current connection speed
Your noise margin has now improved I would suggest you now force a re sync by disconnecting the adsl lead from the phone socket for about 20 seconds and then plugging the lead back in hopefully will cause a resync and improve your speed I suggest you do this during the morning
Message 6 of 19
Max reconnect speed I can achieve is 2.5mps, but a while ago I was achieving 3+
Any idea ?
Message 7 of 19
there may have been some changes in your line conditions that have reduced your speed unfortunately this does happen some times and nothing can be done i am afraid
Message 8 of 19
After being resigned to having this slow speed given my distance from the exchange, I was fairly annoyed to pop into a friends not 100 yards away from myself to find they have 8meg with Sky, a service which I had never tried but am now seriously considering 😞
Message 9 of 19
Even that short distance could mean that they could be connected to a different street cabinet to you, hence the speed difference.
You would still get nearly the same speed with another ISP.
Speed complaints are quite common on the Sky forum.
http://helpforum.sky.com/t5/Sky-Broadband-Speed/bd-p/sky_broadband_speed
Message 10 of 19
Any way to attempt a fix on this or is it just something I have to live with, given the cost of sky being a lot less it's a worry that im paying premium for service i can suffer with for less cost if u know what I mean
