Message 21 of 22
Re: Since I had FTTP installed I can no longer use Powerline Adapters
So how many powerlne adaptors do you currently have on your setup?
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Message 22 of 22
Have you checked the connection speed using a cable directly from the hub to a device?
From what you have done so far, the problem does seem to lie with the hub so it would be good to check the lan port(s) in this way without PowerLine adaptors.
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings icon. If someone answers your question correctly please let other members know by clicking on ’Mark as Accepted solution’
