Message 1 of 3
Sky Channels on BT EPG
HI,
Apologies if this has been covered (I cant find it)
Does anyone know if the "new" cross supply of BT and sky will have the Sky channels on BT's/Youview EPG?
For me an app is Ok for movies and sport its tedious for the entertainment channels
Cheers
2 REPLIES 2
Message 2 of 3
Re: Sky Channels on BT EPG
If you read the BTTV T & C's and in particular this part -
(e) If you have any NOW TV subscriptions that we do not bill you for (for example, content taken via another third party provider that is not BT or NOW TV), you cannot watch that content through your set-top-box electronic programme guide. Instead, you will need to login to the NOW TV app on the set-top-box or another device.
We can deduce that they will be but only if you buy them through BT.
Message 3 of 3
HI,
Thanks for the reply. Lets hope they do pop up on the EPG soon.
