Message 1 of 5
Sky and BT dual band wi fi extender 1200
My Wi fi extender worked with BT home hub but now I have changed to Sky it is not picking anything up
4 REPLIES 4
Message 2 of 5
Re: Sky and BT dual band wi fi extender 1200
I suspect you will either have to reset it to factory default, as Sky use a different LAN IP subnet, or ask on the Sky users forum for the answer. http://www.skyuser.co.uk/forum/
Message 3 of 5
Hi, like Keith said. Restart install of your BT extender from scratch. User guide is available here if you've lost it.
Message 4 of 5
will  I need the password ?
Message 5 of 5
You won't need the password if your Sky router has a WPS button (if it does, use "Method 1" shown in the user guide on the link I showed above).
If your Sky router doesn't have such a button, then you'll need to use Method 2 which does indeed need the password.
You'll need to check with Sky or the Sky forum if you don't know if your router has a WPS button (it's sometimes called "Wireless" too, and you press it to enable WPS).
Hope this helps.
