KautoStar
Message 1 of 10
Sky q boxes and BT Broadband
Hi
im considering getting Sky Q but am a bit put off by suggestions that having a SkyQ box with BT Broadband causes problems with wifi access to other equipment like IPads, etc.
Any advice very much appreciated.
9 REPLIES 9
john46
Message 2 of 10
Re: Sky q boxes and BT Broadband
no problems at all
KautoStar
Message 3 of 10
Many thanks for the rely.
inixon79
Message 4 of 10
I have SKy Q Silver and with 3 x mini sky q on BT broadband HH6 and lots of other wifi devices and all works a treat.  Go for it.
Devon_Dave
Distinguished Guru
Message 5 of 10
Perhaps the suggestion has come from Sky, hoping you will change your BB to them?
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
David_Burditt
Message 6 of 10
How did you connect the BT Hub to the Sky Q boxes so you could take advantage of the Sky Q mesh network and use the Sky boxes as access points?
I’ve connected by Ethernet from the BT hub to the Sky q main box ( I also have a mini and two range extenders) but don’t seem to be able to access the internet via the Sky boxes.
Any thoughts?
David_Burditt
Message 7 of 10
I’ve just switched from Sky to BT as BB provider.
How do I connect my Sky q main box ( I also have a mini and two range extenders) to the BT hub in such a way as to be able to use the Sky boxes as access points for internet.
At the moment I’ve connected via Ethernet from the BT hub to the Sky q box and the Sky Q box can see the internet and is obviously connected because I can use iPlayer, catch up tv etc but the SSID that the box transmits is not the same as the BT Hub name, nor can I access the internet using it.
Am I doing something wrong?
D
Paul_31
Message 8 of 10
@David_Burditt I’ve got Sky Q with BT Infinity and I’m pretty sure the Sky Access Points will only work with Sky broadband and router.
Travelusa
Expert
Message 9 of 10
you can only connect the sky q box to the BT router via the 2g there 5 g is ther own network with the mini box and also connecting to the Sky router via ther mesh
Or connect the box via ethernet if you can
Sky will not allow you to connect ther box to the BT router via the 5G
I have tried as soon as i said i was using a BT Router i got the Version of the Sky ELBOW not our brodband so why should we open up our router to bt
VeteranISPUser
Recognised Expert
Message 10 of 10
D
Hi @David_Burditt
Using the Sky boxes as access points is only available when using the Sky Q Hub and having Sky as your ISP provider. The Skyxxxx you are seeing are used by the Sky Q Mesh and AirPlay etc. You cannot connect to them as WiFi access points.
