Yes but exactly what am I looking for?
In my opinion I would want those two figures to be almost exactly the same but what what tolerance would I reasonably expect them to be the same?
I have a system up time of 6:02:51, WAN 6:01:42 and LAN1 6:02:48. I understand exactly what these are but how close should they be?
Sorry but I am simply trying to understand.
John
Ok John
Thanks for this will do so.
Tonight I'm back up to 7 meg would you believe and a call from BT saying that they have reset my profile and apologies too. I am grateful for this but it does concern me as it has so often in the past that the approach to problems sometimes can cause problems than they solve. If I hadn't put my foot down I would have now had to disconnect the router and plug it into the master test socket with a further disconnection in 24 hours.
I can't help but feel that sometimes BT make a simple problem hard work.
I will keep an eye on the times and once again my sincere thanks for your time.
Regards
John
hello John
Download speed achieved during the test was - 6.37 Mbps
For your connection, the acceptable range of speeds is 0.6 Mbps-7.15 Mbps.
Additional Information:
Your DSL Connection Rate :8.13 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
IP Profile for your line is - 7.15 Mbps
looks good with correct profile and good download throughput
Ah, don't say that, you're only talking up problems!
Like everything while I'm happy that its sorted I would like to know why it happened and I wish BT would get their act together.
Regards to all who helped.
John
