Message 21 of 29
Re: Sloooooooow broadband
Yes but exactly what am I looking for?
In my opinion I would want those two figures to be almost exactly the same but what what tolerance would I reasonably expect them to be the same?
I have a system up time of 6:02:51, WAN 6:01:42 and LAN1 6:02:48. I understand exactly what these are but how close should they be?
Sorry but I am simply trying to understand.
John
Message 22 of 29
no problem you need to keep an eye on the WAN connection time that needs to be continuous for the next 3/ 5 days ideally within a few minuets of each other
Message 23 of 29
Ok John
Thanks for this will do so.
Tonight I'm back up to 7 meg would you believe and a call from BT saying that they have reset my profile and apologies too. I am grateful for this but it does concern me as it has so often in the past that the approach to problems sometimes can cause problems than they solve. If I hadn't put my foot down I would have now had to disconnect the router and plug it into the master test socket with a further disconnection in 24 hours.
I can't help but feel that sometimes BT make a simple problem hard work.
I will keep an eye on the times and once again my sincere thanks for your time.
Regards
John
Message 24 of 29
could you post the diagnostic part of the BT Speedtest for reference please
Message 25 of 29
hello John
 Download speed achieved during the test was - 6.37 Mbps
 For your connection, the acceptable range of speeds is 0.6 Mbps-7.15 Mbps.
 Additional Information:
 Your DSL Connection Rate :8.13 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
 IP Profile for your line is - 7.15 Mbps
Message 26 of 29
looks good with correct profile and good download throughput
Message 27 of 29
looks ok now 😉
Message 28 of 29
Ah, don't say that, you're only talking up problems!
Like everything while I'm happy that its sorted I would like to know why it happened and I wish BT would get their act together.
Regards to all who helped.
John
Message 29 of 29
the best advise I can give you is if you have problems in the future post back here and avoid the hassle of the help line there is a lot of help here and access to the UK based forum mod team who are a small specialist team who take personal ownership of problems until resolved and give a single point of contact
