Message 11 of 20
Re: Slow 80/20 fibre broadband speeds
As your stats show full speed then you may be right about congestion. Which exchange are you connected to and I'll ask a mod to have a look.
It may be tomorrow before they reply.
Message 12 of 20
Exchange RUABON is served by cabinet 14.
When I,ve checked in the past I was always on cabinet 10. So maybe since I,ve gone into cabinet 14 the problems started.
Message 13 of 20
Oh and by the way thanks to everyone for trying to help!
Message 14 of 20
Hi @Masterplan I can't see any reported congestion problems for your exchange area, is your computer connected directly to your router via ethernet or do you use powerline adapters?
Message 15 of 20
Thanks for checking congestion.
I always use my pc via an ethernet connection. Never use the wi-fi connection.
Tonights speedtests
SpeedOf.Me Test Result
https://www.thinkbroadband.com/_assets/speedtest/button/1551040086685252655.png
Results Image not loaded
1. Best Effort Test: -provides background information.
 Download Speed
 9.22 Mbps
0 Mbps20 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 9.22 Mbps
 Additional Information:
 IP Profile for your line is - 20 Mbps
2. Upstream Test: -provides background information.
 Upload Speed
 9.22 Mbps
0 Mbps20 Mbps
Upload speed achieved during the test was - 9.22Mbps
 Upstream Rate IP profile on your line is - 20 Mbps
Message 16 of 20
@NeilO was asking whether you were using a direct wired connection to the Hub or via powerline adapters.
Message 17 of 20
Don't do another BTWholesale test as  it will overight this one on their server. Wait for @NeilO to get back to you.
Message 18 of 20
Direct ethernet connection directly to my router.  I do not use powerline adaptors
Message 19 of 20
Speed has improved a little between 30-40mbps.
It is still not good enough for an 80/20 connection. Looks like BT are capping my speed if there is no congestion.
My mobile phone runs faster than my fibre connection!
Message 20 of 20
If it isn't congestion, then it's either the device you're using or something internal that's causing the problem.
