mattd
Message 1 of 8
Slow ADSL (SNR > 30dB)
Hi,
Please can you assist with a DLM reset / reconfig on my line. SNR is currently >30dB, and sync speed around 1Mbps. Please see the router stats below. The line length is approx 2.5km and should be providing much more than 1Mbps.
It looks like the line is on a fixed 1Mbps profile, rather than ADSL Max.
ADSL line status
Connection information
Line stateConnected
Connection time6 days, 1:30:39
Downstream1,152 Kbps
Upstream288 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
ModulationITU-T G.992.1
Latency typeFast
Noise margin (Down/Up)30.2 dB / 26.0 dB
Line attenuation (Down/Up)34.0 dB / 19.0 dB
Output power (Down/Up)12.2 dBm / 12.2 dBm
Many thanks,
7 REPLIES 7
imjolly
Message 2 of 8
Re: Slow ADSL (SNR > 30dB)
certainly looks like 1mb fixed connection.
as you have poste dthe current stats can you try 1 reset and repost stats and see if comes back the same please
john46
Message 3 of 8
almost certainly a fixed line speed
imjolly
Message 4 of 8
previous posts in 6/14 were adslmax so if 1 reset does not change stats then need mod help
mattd
Message 5 of 8
Hi,
This is a different line to the one referred to in previous posts 🙂
Definitely a 1Mbps fixed profile 🙂 the 288 upload is a giveaway. Hopefully the mods can help so I don't have to go near the call centre. 🙂
ADSL line status
Line stateConnected
Connection time0 days, 0:10:25
Upstream288 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
Latency typeFast
Noise margin (Down/Up)30.1 dB / 26.0 dB
Line attenuation (Down/Up)33.9 dB / 19.0 dB
Output power (Down/Up)12.3 dBm / 12.2 dBm
imjolly
Message 6 of 8
the mods will post a contact us link
After completing the email NOT PM then you join a queue of other customers waiting for mod help. The mods will get back to you in 3/5 working days either by phone or email
DavidM
Moderator
Moderator
Message 7 of 8
Hi mattd,
Thanks for posting. I'll take a look at this for you. Just drop me an email with the details. You'll get the 'contact us' link in my profile.
Cheers
David
mattd
Message 8 of 8
Thanks 🙂
