rah299
Message 1 of 8
Slow Broadband Connection
Hi
The broadband connection that I am receiving is much lower than suggested when I originally signed up.
I spoke to a Technical advisor on sunday as the I was getting a speed of 0.6mbps and asked them to reset my profile. I was advised that I would get a speed of approx 6mbps.
Nothing improved in my connection over the next couple of days so I phoned again and was told that a technical advisor would phone me back this evening which has not happened so was hoping someone on here will be able to help.
Things have got slightly better today and my connection has creeped back up to around 1mbps but this is stil obviously nowhere near the speed advertised.
My stats are as follows:
Connection Information
Line state:Connected
Connection time:0 days, 03:37:43
Downstream:1.688 Mbps
Upstream:448 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.1 Annex A
Latency type:Interleaved
Noise margin (Down/Up):7.4 dB / 21.0 dB
Line attenuation (Down/Up):49.8 dB / 29.0 dB
Output power (Down/Up):18.7 dBm / 12.5 dBm
FEC Events (Down/Up):2283 / 0
CRC Events (Down/Up):4 / 0
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):22 / 0
Error Seconds (Local/Remote):977 / 273
Rob
7 REPLIES 7
Message 2 of 8
Re: Slow Broadband Connection
with your attenuation I would be hoping for about 5mb on a good line with no noise problems.
your connection time is only 3+hrs is that due to the router resetting or manual reset?
are you connected to the test socket or master socket?  do you have other sockets apart from the master?
rah299
Message 3 of 8
I am connected to the master socket with an accelerator fitted to it. There are no other sockets The router must have reset itself as I have not turned it off.
Message 4 of 8
with your line attenuation (line length) the best you can expect to achieve is 4.8mb
Message 5 of 8
the accelrator is really intended for customers who have extension sockets as te accelerator is to reduce the noise cause by the bellwire from extension wiring.  have you tried connecting to the test socket without the accelerator and post your stats
rah299
Message 6 of 8
Hi I have tried the test socket without the accelerator but no signs of improvement ADSL Line Status Connection Information Line state: Connected Connection time: 3 days, 23:41:41 Downstream: 1.563 Mbps Upstream: 448 Kbps   ADSL Settings VPI/VCI: 0/38 Type: PPPoA Modulation: G.992.1 Annex A Latency type: Interleaved Noise margin (Down/Up): 6.6 dB / 21.0 dB Line attenuation (Down/Up): 49.5 dB / 28.5 dB Output power (Down/Up): 18.6 dBm / 12.5 dBm FEC Events (Down/Up): 85935 / 360 CRC Events (Down/Up): 911 / 718 Loss of Framing (Local/Remote): 0 / 0 Loss of Signal (Local/Remote): 0 / 0 Loss of Power (Local/Remote): 0 / 0 HEC Events (Down/Up): 6831 / 637 Error Seconds (Local/Remote): 94 / 47       Thanks Rob Hide details
Message 7 of 8
are these stats with the router connected directly to the test socket via a filter?
rah299
Message 8 of 8
