Message 11 of 42
Re: Slow Broadband Speed.
Will do. Will one tonight, one tomorrow morning, and one this time tomorrow be ok?
Message 12 of 42
that will be fine thanks
Message 13 of 42
what was the connection time for the router stats you posted.  a lot of errors especially if connection time low
Message 14 of 42
I just restarted my router 30 minutes ago to see if it would make a difference, so can't tell you an exact figure. But I would guess that it had been up and running for at least a few weeks without a restart.
Message 15 of 42
just because you have not restarted/reset the router does not mean there have been no dropped connections. if unsure about time can your post stats again but this time include the connection time.  I'm trying to see connection time and the amount of errors during tha time
Message 16 of 42
Ah right, misunderstood what you were after, here you go:
ADSL Line Status
Connection Information
Line state:Connected
Connection time:0 days, 00:38:29
Downstream:6.469 Mbps
Upstream:448 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.1 Annex A
Latency type:Fast
Noise margin (Down/Up):6.0 dB / 18.0 dB
Line attenuation (Down/Up):43.0 dB / 26.5 dB
Output power (Down/Up):19.9 dBm / 12.3 dBm
FEC Events (Down/Up):0 / 1
CRC Events (Down/Up):120442 / 6
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):66707 / 0
Error Seconds (Local/Remote):2655 / 62
Message 17 of 42
thereare quite a few errors for only 38min connected.  can you possibly borrow a phone just to do the quiet line test?
if you are not a gamer then switching latency to interleaved will help stabilise your conenction
Message 18 of 42
I am a gamer I'm afraid. Will try to get a phone later.
Message 19 of 42
ok  still remember to post btspeedtester results
Message 20 of 42
Speedtest results for tonight.
Download speedachieved during the test was - 1134 Kbps For your connection, the acceptable range of speeds is 600-7150 Kbps. Additional Information: Your DSL Connection Rate :6080 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM) IP Profile for your line is - 5000 Kbps
