Message 21 of 42
Re: Slow Broadband Speed.
one after midnight would be helpful
Message 22 of 42
Download speedachieved during the test was - 4324 Kbps
 For your connection, the acceptable range of speeds is 600-7150 Kbps.
 Additional Information:
 Your DSL Connection Rate :6080 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
 IP Profile for your line is - 5000 Kbps
Now that it's past midnight by internet seems to have sped up, any reasons for this?
Message 23 of 42
Hi as I suspected your speed has increased as you came out of peak time we need more tests over the next 24 hours then you can get the mods involved with the problem the more evidence they have the easier they can get the problem resolved
Message 24 of 42
It is not the problem with the line that will be
a mulit pair cable that is designed to do To have have the cable renewed if Openreach would change you would need to order a completely new line at 130.00 and there is every chance that he would users spare pair in the same cable so unlessthe line is not working at all there is no point the problem is not at your end this is why we are asking for more Bt speed tests as the problem is more likely exchange based
Message 25 of 42
Another speed test from just now:
 Download speedachieved during the test was - 3980 Kbps
Speed seems ok at the moment, I'll take another if it seems to drop again.
Could it really be the exchange if other rooms on the same 'line' from the telephone pole aren't having the same problem though?
Message 26 of 42
you would need to get the others to run btspeedtester at the same time as yours when the problems are on your connection.  congestion would normally affect everyone
Message 27 of 42
Imj some times not as theycould be on a different VP as some exchanges have multi ones can be dependent onowmany msan's are installed I have seen this on my own exchange before
Message 28 of 42
ah ok  john46
then check your exchange here to see if anything shown  http://usertools.plus.net/exchanges/mso.php
http://usertools.plus.net/exchanges/?
http://btbusiness.custhelp.com/app/service_status
http://bt.custhelp.com/app/answers/detail/a_id/15036
Message 29 of 42
No reported issues with my exchange...
My exchange should be this: CMALB
Message 30 of 42
the VP is green but interestingly the previous 5 months were yellow
