Message 31 of 42
Re: Slow Broadband Speed.
What does it take for an engineer to get involved in this problem? Just curious.
Message 32 of 42
if your btspeedtest results show spe is ok at offpeak time and dropping at peak times then if it is dropping below the shown acceptablelimit then you can contact the mods who will report the problem to wholesale.  the problem will be at the exchnage and not your home if it is congestion
Message 33 of 42
Another poor speed test.....
Download speedachieved during the test was - 326 Kbps For your connection, the acceptable range of speeds is 600-7150 Kbps. Additional Information: Your DSL Connection Rate :6080 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM) IP Profile for your line is - 5000 Kbps
As long as I can get the speeds up to within the acceptable limit during peak times I'd be happy!
Message 34 of 42
looks very much like congestion from that result suggest you contact the mods and ask them to investigate for you this is a link to them
http://bt.custhelp.com/app/contact_email/c/4951
they normally reply by email or phone directly to you within 72 hours
They are a UK based BT specialist team who have a good record at getting problems solved
Message 35 of 42
Should I just direct them to this thread where they can see the issue? Or do I need to describe it from scratch to them...?
Message 36 of 42
just point the mods to this thread
Message 37 of 42
Ok done that, hopefully this can get resolved soon! I'll be moving to my next base in April, if they can't get this sorted sometime before then, then I'm afraid I'll go with another ISP.
Message 38 of 42
changing isps will not get rid of congestion problems i am afraid it will affect all isps
Message 39 of 42
Yeah I understand that, it's more the ISP's ability to resolve a problem within a reasonable amount of time that's the issue.
Doesn't help when they say they will call you at a certain time, you change your personal arrangements so that you can be free at that time, and then you receive no phone call...
Message 40 of 42
The work is carried out by BT Wholesale/Openreach regardless of ISP they all have to go through them they manage the network
