AndrewJenkins
Message 1 of 9
Slow Broadband Speed
If anyone can help...
I have been suffering slow speeds (0.13 down and 0.28 up) for a week and a half.
Tried all the tests and an engineer visited. He replaced the line box and got the exchange to reset something.
Nothing has improved and the engineer is coming back, but I thought I would share this before the next visit.
The router details are below.
Router Status
Account Name
Firmware Version
V2.10.22
ADSL Port
MAC Address
00:0F:1F:14:99:DC
IP Address
217.43.172.51
Network Type
PPPoA
IP Subnet Mask
255.255.255.255
Gateway IP Address
217.41.191.186
Domain Name Server
213.120.234.66
213.120.234.2
LAN Port
MAC Address
00:0f:b5:ce:b0:ea
IP Address
192.168.0.1
DHCP
On
IP Subnet Mask
255.255.255.0
Modem
ADSL Firmware Version
3.02.06.00
Modem Status
Connected
DownStream Connection Speed
3840 kbps
UpStream Connection Speed
448 kbps
VPI
0
VCI
38
Wireless Port
Name (SSID)
Andrew
Region
Europe
Channel
6
Wireless AP
Enabled
Broadcast Name
Enabled
System Up Time 24:24:21
Port
Status
TxPkts
RxPkts
Collisions
Tx B/s
Rx B/s
Up Time
WAN
PPPoA
274548
336616
0
361
2784
24:23:48
LAN
100M/Full
342351
320941
0
2844
558
24:24:17
WLAN
11M/54M
42511
4825
0
125
4
24:24:07
ADSL Link
Downstream
Upstream
Connection Speed
3840 kbps
448 kbps
Line Attenuation
40 db
11.5 db
Noise Margin
10 db
24 db
8 REPLIES 8
Message 2 of 9
Re: Slow Broadband Speed
you currently have a 3.8mb connection speed but your noise margin at 10 is higher than normal 6.
can your run btspeedtester not beta and post the results
AndrewJenkins
Message 3 of 9
Ran it and it came back with 102 kbps but then it mentions error getting additional info and so can't verify if speed is acceptable for he service.
Many thanks for getting back to me.
Message 4 of 9
I was looking for you to post the results as not only does it show download speed but just as important it shows your current profile.  your profile determines your download speed and this is only checker that will show your profile
AndrewJenkins
Message 5 of 9
It only returned the best effort test 1
What should I do?
Message 6 of 9
if you ran the standard test 1 at btspeedtester then you need to wait 1 hr before you can run the test again
AndrewJenkins
Message 7 of 9
I have tried re-running that test before and it always comes up with just the first result and nothing more.
Message 8 of 9
if you use the link http://www.speedtester.bt.com/   you should just tick yes the click adsl and FTTC - next page enter phone number no service id required and then go, confirm phone number and test 1 should run
AndrewJenkins
Message 9 of 9
Sorry I don't get anything more than the speed I mentioned in the previous post. I tried this test many times in the last 2 weeks and it has never produced anything more than that.
