Message 1 of 10
Slow Broadband after line fault fixed
Hi,
After a fault was fixed on the line two weeks ago Broadband speed has been incredibly slow - 32kBs at the most (previously it was around 400kBs)
After replacing the microfilter, resetting the router, plugging directly into the test socket I just left it alone but have seen no improvement.
Tried the quiet line test and all seems fine.
Looks like the router disconnected at least once, otherwise the connection time should be longer
Stats today...
Line state:Connected
Connection time:3 days, 22:43:33
Downstream:287.1 Kbps
Upstream:1.088 Mbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.5 Annex A
Latency type:Interleaved
Noise margin (Down/Up):10.9 dB / 4.9 dB
Line attenuation (Down/Up):44.2 dB / 28.1 dB
Output power (Down/Up):17.6 dBm / 12.7 dBm
FEC Events (Down/Up):134945 / 6918
CRC Events (Down/Up):0 / 341
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):0 / 246
Error Seconds (Local/Remote):0 / 211
Any suggestions would be appreciated
Also I saved the stats from the 29th Sept, the day after the line was fixed if they are any use, much the same except Noise Margin was 14.9 dB / 10.6 dB
9 REPLIES 9
Message 2 of 10
Re: Slow Broadband after line fault fixed
Hi
I am sorry to see you are having problems with your BT Service
I suggest you contact the forum mods they should be able to reset your noise margin for you  sorted for you this is a link to them http://bt.custhelp.com/app/contact_email/c/4951
They normally reply by email or phone directly to you within 3 working days they will take personal ownership of your problem until resolved and will keep you informed of progress
They are a UK based BT specialist team who have a good record at getting problems solved
This is a customer to customer self help forum the only BT presence here are the forum moderators
Message 3 of 10
Hi John,
thanks for the speedy reply.
Have emailed and will let you know of any progress
Message 4 of 10
please do as it helps others
Message 5 of 10
john46 I would have expected the noise margin to be higher with the 287 connection speed maybe suggesting there is a line problem rather than just a noise margin reset
Message 6 of 10
i thought of a banded profile but the noise margin did not appear correct for that
Message 7 of 10
more like a problem caused when the previous line fault was fixed
Message 8 of 10
it certainly needs the mods help to sort this one
Message 9 of 10
Hi,
Yesterday mods replied that there was indeed still a fault (didn't specify what) and they were looking into it.
This morning broadband was back and faster than ever
Thanks to all involved
My current stats, in case anyone's interested...
Connection time:0 days, 13:14:59
Downstream:5.615 Mbps
Upstream:1.04 Mbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Noise margin (Down/Up):9.6 dB / 5.7 dB
Output power (Down/Up):19.8 dBm / 12.7 dBm
FEC Events (Down/Up):379372 / 686
CRC Events (Down/Up):471 / 60
HEC Events (Down/Up):6422 / 41
Error Seconds (Local/Remote):277 / 169
Message 10 of 10
Great news glad all is now ok
