Message 11 of 26
Re: Slow Broadband.
Maybe why other ISP's have more preference over BT in that sense then.
imjolly
Message 12 of 26
Re: Slow Broadband.
Only TT is shown as an LLU provider on th OP's exchange
john46
Message 13 of 26
Re: Slow Broadband.
@William_Grimsley
if you look on the samknows site you will see a list of LLU exchanges for any exchage you select
Message 14 of 26
Re: Slow Broadband.
@john46, thanks.
john46
Message 15 of 26
Re: Slow Broadband.
hope it helps you a little
newpersn
Message 16 of 26
Re: Slow Broadband.
Back to my problem
I can't even stream a radio station. There's nothing else using the connection.
john46
Message 17 of 26
Re: Slow Broadband.
Can you use this speed tester then carry out the further diagnostics and post back a screen shot of all the results including your IP profile for up and down. This test must be done with a wired connection.
http://speedtest.btwholesale.com/
if you have a Homehub 4 or 5 can you also post the stats from 1-12 by logging onto the homehub management pages then troubleshooting > helpdesk. http://bthomehub.home/
newpersn
Message 18 of 26
Re: Slow Broadband.
Hub:
Product Name:
HomeHub4
2.
Serial number:
+076281+1612001240
3.
Firmware version:
v0.07.03.30329-BT (Type B) Last updated 1/7/2016
4.
Board version:
01B
5.
DSL uptime:
1 days, 23:16:13
6.
Data Rate:
448 / 8128
7.
Maximum Data Rate:
1016 / 8380
8.
Noise Margin:
21.0 / 6.5
9.
Line Attenuation:
15.5 / 22.5
10.
Signal Attenuation:
0.0 / 22.5
11.
Data sent/received:
0.2 GB / 3.0 GB
12.
Broadband username:
bthomehub@btbroadband.com
13.
BT Wi-fi:
14.
2.4GHz wireless network/SSID:
BTHub4-QRCF
15.
2.4GHz wireless connections:
Enabled (802.11 b/g/n (up to 144 Mb/s))
16.
2.4GHz wireless security:
WPA & WPA2 (Recommended)
17.
2.4GHz wireless channel:
Automatic (Smart Wireless)
18.
5GHz wireless network/SSID:
BTHub4-QRCF
19.
5GHz wireless connections:
Enabled (802.11 n (up to 300 Mb/s))
20.
5GHz wireless security:
WPA2 Only
21.
5GHz wireless channel:
22.
Firewall:
Default
23.
MAC Address:
d4:63:fe:54:5a:c8
24.
VPI/VCI:
0/38
25.
Modulation:
G.992.1(DMT)
26.
Latency type:
Fast
27.
Software variant:
28.
Boot loader:
0.5.0-BT (Wed Nov 12 11:47:59 2014)
Speedtest:
newpersn
Message 19 of 26
Re: Slow Broadband.
My pings
C:\Users\xxxx>ping 8.8.8.8
Pinging 8.8.8.8 with 32 bytes of data:
Reply from 8.8.8.8: bytes=32 time=832ms TTL=55
Reply from 8.8.8.8: bytes=32 time=641ms TTL=55
Reply from 8.8.8.8: bytes=32 time=556ms TTL=55
Reply from 8.8.8.8: bytes=32 time=766ms TTL=55
Ping statistics for 8.8.8.8:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 556ms, Maximum = 832ms, Average = 698ms
C:\Users\xxxx>ping bbc.co.uk
Pinging bbc.co.uk [212.58.244.22] with 32 bytes of data:
Reply from 212.58.244.22: bytes=32 time=1050ms TTL=50
Reply from 212.58.244.22: bytes=32 time=1049ms TTL=50
Reply from 212.58.244.22: bytes=32 time=1058ms TTL=50
Reply from 212.58.244.22: bytes=32 time=1063ms TTL=50
Ping statistics for 212.58.244.22:
Minimum = 1049ms, Maximum = 1063ms, Average = 1055ms
C:\Users\xxxx>ping www.yahoo.co.uk
Pinging src.g03.yahoodns.net [77.238.184.150] with 32 bytes of data:
Reply from 77.238.184.150: bytes=32 time=980ms TTL=51
Reply from 77.238.184.150: bytes=32 time=1077ms TTL=51
Reply from 77.238.184.150: bytes=32 time=1042ms TTL=51
Reply from 77.238.184.150: bytes=32 time=1051ms TTL=51
Ping statistics for 77.238.184.150:
Minimum = 980ms, Maximum = 1077ms, Average = 1037ms
john46
Message 20 of 26
Re: Slow Broadband.
Could you please run the further diagnostic part of the speedtest and post back the full results of the test this must be done using a wired connection
