Message 1 of 63
Slow Broadband
Hi,
Until 1700 Monday my Broadband download speed was around 15.5Mb/s. it  suddenly dropped to around 2Mb/s. and last night it was down to 1.5Mb/s. That was after  reporting a fault to BT and being informed by text that it was rectified. I have rebooted the router as suggested.
I have a Netgear DGND3700 router
Can anyone give any advice please?
Thanks in advance.
Steve.
Steve.
62 REPLIES 62
Message 2 of 63
Re: Slow Broadband
can you please post the adsl stats from your netgear and also run btspeedtester not beta and post results
Message 3 of 63
Re: Slow Broadband
Hi Welcome to the forums
Here is a basic guide to getting help from the community members done by CL Keith Please read through the link posted http://forumhelp.dyndns.info/speed/first_steps.html
once you have posted the information asked for then the community members can help you more
Thank You
This is a customer to customer self help forum the only BT presence here are the forum moderators
Message 4 of 63
Re: Slow Broadband
Hi John,
Sorry it's taken so long to reply.  I was at work when I started the thread.
Router Status
Hardware Version DGND3700
Firmware Version V1.0.0.17_1.0.17
GUI Language Version V1.0.0.15
Internet Port
MAC Address
IP Address
Network Type PPPoE
IP Subnet Mask 255.255.255.255
Gateway IP Address 217.32.140.72
Domain Name Server <!> 213.120.234.34 213.120.234.54
LAN Port
MAC Address
IP Address 192.168.0.1
DHCP On
IP Subnet Mask 255.255.255.0
Modem
ADSL Firmware Version A2pv6C035g.d23k
Modem Status connected
DownStream Connection Speed 1461 kbps
UpStream Connection Speed 147 kbps
VPI 0
VCI 38
Wireless Port
Region Europe
Wireless Settings (2.4GHz b/g/n)
Name (SSID)
Channel Auto (1)
Mode Up to 54 Mbps
Wireless AP On
Broadcast Name On
Wireless Isolation Off
Wireless Settings (5GHz a/n)
Name (SSID)
Channel 36
Mode Up to 54 Mbps
Wireless AP On
Broadcast Name On
Guest Network
Guest Profile 2
Wireless AP Off
Guest Profile 3
Wireless AP Off
Guest Profile 4
Wireless AP Off
Guest Profile 2
Wireless AP Off
Guest Profile 3
Wireless AP Off
Guest Profile 4
Wireless AP Off
I can find several speed checkers, can you send me a link to the correct one please.
Regards,
Steve.
Steve.
Message 5 of 63
Re: Slow Broadband
your network type should be pppoA not pppoE which for cable or infinity
http://speedtest.btwholesale.com/
if you go to router status and then show statistics can you post the data please
Message 6 of 63
Re: Slow Broadband
Hi,
Speed test results:
Download speed (Mbs) 1.9
Upload speed (Mbs) 1.03
Ping latency 25.00
Made the change:
Router Status
Hardware VersionDGND3700
Firmware VersionV1.0.0.17_1.0.17
GUI Language VersionV1.0.0.15
Internet Port
MAC Address 84:1B:5E:47:DC:C5
IP Address 86.152.0.158
Network Type PPPoA
LAN Port
MAC Address 84:1B:5E:47:DC:C4
DHCP On
Modem
ADSL Firmware VersionA2pv6C035g.d23k
Modem Statusconnected
DownStream Connection Speed2268 kbps
UpStream Connection Speed1216 kbps
VPI0
VCI38
Wireless Port
RegionEurope
Name (SSID)
ChannelAuto (11)
ModeUp to 54 Mbps
Wireless APOn
Broadcast NameOn
Wireless IsolationOff
Name (SSID)
Channel36
ModeUp to 54 Mbps
Wireless APOn
Broadcast NameOn
Guest Network
Guest Profile 2
Wireless APOff
Guest Profile 3
Wireless APOff
Guest Profile 4
Wireless APOff
Guest Profile 2
Wireless APOff
Guest Profile 3
Wireless APOff
Guest Profile 4
Wireless APOff
Steve.
Message 7 of 63
Re: Slow Broadband
Hi,
Just to mention;
I checked the 'Test port' on the BT socket when the telephone line comes into the house.
Same speed there to.
Steve.
Steve.
Message 8 of 63
Re: Slow Broadband
Sorry, mis-read your reply.
System Up Time <!>00:09:36<!>
PortStatusTxPktsRxPktsCollisionsTx B/sRx B/sUp Time
WANpppoa53446400048251227700:08:57
LAN1Link Down8663755501313013--
LAN21000M00:09:26
LAN31000M00:09:26
LAN4Link Down--
WLAN b/g/n54M726250036612200:08:53
WLAN a/n54M62915406052400:08:53
ADSL LinkDownstreamUpstream
Connection Speed2268 kbps1216 kbps
Line Attenuation11.5 db4.0 db
Noise Margin18.6 db6.6 db
Steve.
Message 9 of 63
Re: Slow Broadband
testsocket2.jpgit was this port you tried ?
Message 10 of 63
Re: Slow Broadband
John,
That's the one.
I assumed(?) it would isolate a cabling fault in the house.
Thanks,
Steve.
Steve.
