Recognised Expert
Message 1 of 22
Slow Connecting to Broadband
Hello There,
  I have a homehub v2. For 2 years no problem always connected wirelessly, home hub situated next to computer.
For the past week very slow connecting to Broadband sometimes won't connect at all until with a bit of fiddling it does
I have for 5 days connected by ethernet cable but still no difference, once connected speed seems fine.
All the lights on hub are blue the hub is left on 24/7
The hub is in a extension socket installed by BT(not recently) with a filter. I have rebooted the hub, turned off at mains etc,
Can anyone advise me further    Thanks Patty-L
21 REPLIES 21
Message 2 of 22
Re: Slow Connecting to Broadband
Here are some help pages done by CL Keith http://www.btinternet.com/~cbeddoe/speed/Speed.html
also post your full hub stats details shown in this link http://www.btinternet.com/~cbeddoe/others/adslstats.html
Can you also post the full results fromBT Speedtest speedtester.bt.com
Have you tried connecting to the test socket at the rear of the master socket
Have you tried the quiet line test? - dial 17070 option 2 - should hear nothing - best done with a corded phone. if cordless phone you may hear a 'dull hum' which is normal
This is a customer to customer self help forum the only BT presence here are the forum moderators
Message 3 of 22
did you try inssider to see if any new networks broadcasting round about you?  did you check that your network card has the most up to date drivers from the manufacturer's website - not from windows update?
Recognised Expert
Message 4 of 22
Hi john, unable to open Keiths links
quiet line test quiet (corded phone)
now you are getting technical so I will have to have time to sort it out... if I could open links to tell me how.
@ imjolly foxed by network card computer 1Yr old
Thanks for your replies
Message 5 of 22
adsl stats
wireless help
wireless boost
will these links work for you
Message 6 of 22
if you go control panel then system and security then system then device manager then network adapter then driver you should see manufacturer and cna then try to see if any updated driver
Recognised Expert
Message 7 of 22
imjolly yes the links work now (haven't done anything as yet)
Oh dear!! can't find 2nd one, get as far as network sharing no network adapter. Running Vista.
Distinguished Guru
Message 8 of 22
Hi Patty,
Click start and type in ncpa.cpl in the search banner and press enter
From the window that now opens, right click on the wireless network connection, select properties
(click continue)
Click configure, then select driver.
make a note of what info given, for example, intel wireless 1234abg, driver date, driver version.
One of us will check to see if it's up to date;)
-+-No longer a forum member-+-
Recognised Expert
Message 9 of 22
Hello DS,
I have done as you said I don't know if I have done it right, it says:-
Atheros AR5B91 Wireless Network Adapter
This device is working properly
  Driver date 9/4/09            It certainly doesn't look up to date
  Driver version   7.6.1.237
Thanks all for your help in trying to solve this.
Message 10 of 22
here is the up to date driver
http://www.atheros.cz/atheros-wireless-download.php?chipset=28&system=3   for 64bit
r
http://www.pcpitstop.com/drivers/download/Atheros~AR5B91~Wireless~Network~Adapter.html   for 32bit
