Distinguished Guru
Message 11 of 22
Re: Slow Connecting to Broadband
Ah ha, that's NOT the latest one;)
Have a look here, the newer one is at the top, the older ones are lower down - http://www.atheros.cz/atheros-wireless-download.php?chipset=28&system=4
you need to know if your vista is 32bit or 64bit
(my guess it's the first one)
-+-No longer a forum member-+-
Message 12 of 22
that looks like same website as mineSmiley Wink
Recognised Expert
Message 13 of 22
I am really acting dull now. how can I tell what bit my vista is.
   EDIT   found it 32 bit  before you answered imjolly thanks though
I'm OK with computers so long as everything is working.
Message 14 of 22
go to my computer right click then properties   should say 32 or 64 bit operating system
Distinguished Guru
Message 15 of 22
So it does;)
Patty, carry on, you're doing fine:)
Message 16 of 22
just post for any help Patty we will help all we can
Recognised Expert
Message 17 of 22
Hi   John, imjolly and DS,
The only update I have is that I downloaded the new driver for the network card.  I then turned off the computer for half an
 hour,  re-booted wirelessly it took just over 1 minute to boot up and connect so I am Smiley Happy  now,  lets hope it continues.
Thank you all for your help. I really don't know which post to mark as solved so it will be pot luck.
Patty
Distinguished Guru
Message 18 of 22
Mark your one above, any future readers will more than likely read the whole thread anyway:)
Glad to hear it appears to be sorted
You know where we are if anything goes wrong;)
Message 19 of 22
yeah  mark your own post that way anyone looking will see you appear to have fixed it
Recognised Expert
Message 20 of 22
Too late gents I had already marked the wrong one.
