tracy1210
Message 1 of 2
Slow Connection and High Error Rate
Noticed a problem in last couple of weeks after changing from homehub 2 to homehub 3 although that could be a coincidence.  At time the connection slows to a crawl and other times the connection seems to die and web pages time out from loading etc.
I have checked the stats on the router (posted below) and have noticed a huge number of errored seconds which would explain the problems I have been experiencing.  I would be grateful if someone from BT can take a look.
ADSL line status
Line State                                                  Connected
Connection time                                          4 days 02.35:54
Downstream                                               3.117 mbps
Upstream                                                   715.8 kbps
ADSL Settings
VPI/VCI                                                      0/38
Type                                                          PPPoA
Modulation                                                  G.992.1.Annex A
Latency type                                                Fast
Noise Margin                                                2.4 dB/5.4 dB
Line attenuation (Down/Up)                           58.9 dB/36.5 dB
Output power (Down/Up)                              17.7 dBm/12.5 dBm
Loss of Framing (Local/Remote)                     0/0
Loss of Signal (Local/Remote)                        0/0
Loss of Power (Local/Remote)                        0/0
FEC Errors (Down/Up)                                   0/0
CRC Errors (Down/Up)                                  207802/8580
HEC Errors (Down/Up)                                  1351038/11137
Error Seconds (Local/Remote)                        35749/2867
1 REPLY 1
imjolly
Message 2 of 2
Re: Slow Connection and High Error Rate
this is a community forum where customers help customers and the only BT employees are the forum mods.
in order for the forum members to help please can you post the   adsl stats  from your router may need to 'show detail' to get all stats (if hub enter 192.168.1.254 in your browser and navigate to adsl or use a-z, if netgear enter 192.168.0.1) and run btspeedtester (MAC users may have problems) bt speedtester  and post the results .
are you connected directly via a filter to the NTE5 master or test socket or to somewhere else? Is the master the only phone socket in your home?
Have you tried the quiet line test? - dial 17070 option 2 - should hear nothing - best done with a corded phone. if cordless phone you may hear a 'dull hum' which is normal
Someone may then be able to offer help/assistance/suggestions to your problem
