Message 11 of 14
Re: Slow Download Speed Or NONE
You are suffering from exchange congestion i suggest you contact the forum mods at this link http://bt.custhelp.com/app/contact_email/c/4951 and ask if they could sort this issue for you they normally respond within 72hours and are very good at getting these sorts of issues sorted they reply directly to you by email or phone they are UK based specialists
andy203
Message 12 of 14
Thank you John =
All time low 1945hrs speed test result
This Test comprises of Best Effort Test: -provides background information.
 Download  Speed
 358 Kbps
0 Kbps7150 Kbps
Max Achievable Speed
 Download speedachieved during the test was - 358 Kbps
 For your connection, the acceptable range of speeds is 600-7150 Kbps.
 Additional Information:
 Your DSL Connection Rate :4672 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
 IP Profile for your line is - 4000 Kbps
99ron
Newbie
Message 13 of 14
same problems here.
I have a sync at 8128Kbps.
Download speeds around 550Kbps this evening..
It's fine during the day.
http://www.speedtest.net/result/1396174052.png
I'm in a small village with it's own exchange - I doubt you all live there to so this is an issue higher in BT's network.
I'd guess an MSIL congestion issue?
I think we route through Reading/Slough from here.
Certainly a BT problem though... about time they admitted something is wrong and told us how long it's going to take to fix.
Message 14 of 14
Hi exchange congestion is an ongoing problem BT Wholesale areconstantly upgrading the exchanges and network and congested exchanges are regularly updated to increase capacity the problem affects all ISPs not just BT
