THOMAS-P
Message 1 of 6
Slow Download Speed
Hi, I had BT broadband activated last Tuesday and have been very dissapointed with the speed I have been getting. The first 10 days have now passed and I have seen no improvement.
When I input my phone number on the BT site they say I can achieve:
2Mb *
Estimate download speed
2Mb-7.5Mb
Download speed range
But my download speed is nowhere near this.
I have a grey openworld box outside the property (built 2011) and can't find a master socket inside the property.
Here are my test results:
ADSL Line Status
Connection Information
Line state:           Connected
Connection time:            0 days, 19:12:03
Downstream:    704 Kbps
Upstream:           448 Kbps
ADSL Settings
VPI/VCI:               0/38
Type:     PPPoA
Modulation:       G.992.1 Annex A
Latency type:     Interleaved
Noise margin (Down/Up):             6.4 dB / 10.0 dB
Line attenuation (Down/Up):       66.2 dB / 31.5 dB
Output power (Down/Up):           14.3 dBm / 12.5 dBm
FEC Events (Down/Up):               23261 / 548
CRC Events (Down/Up):                195 / 26
Loss of Framing (Local/Remote):              0 / 0
Loss of Signal (Local/Remote):                 0 / 0
Loss of Power (Local/Remote):               0 / 0
HEC Events (Down/Up):                456 / 11
Error Seconds (Local/Remote):           125 / 28
BT PERFORMANCE TEST
Download: 0.66mbps
Upload: 0.39mbps
Ping latency ms : 46.25
BT Performance test was done through ethernet cable.
Anything which could be causing this? I know it is not my laptop, as i was achieving speeds 10x faster with Sky last month (previous property).
Many Thanks
5 REPLIES 5
john46
Message 2 of 6
Re: Slow Download Speed
if you have the outside box you will not have a master socket the first socket will be the one nearest the point of cable entry into the house from your attenuation you are on a very long line and are unlikely to achieve a fast connection i would expect with a perfect line approx 1.4 mb as your noise margin is also at its default setting i can see no possible room for any improvement
THOMAS-P
Message 3 of 6
Thanks for your help. So it won't be worth calling BT customer services?
I assume it would be a similar speed for all ISP around here then?
Last question, they say I can upgrade to BT infinity with speeds of
49.1Mb
Download speed
10.9Mb
Upload speed
Am i likely to achieve any where near these speeds?
john46
Message 4 of 6
correct you would get the same from any ISP as to infinity in most cases the speed shown is fairly conservative in most cases it can be higher than quoted for example i as quoted 66 -20 and on installation got 77 -20 and that speed has hardly varied since March 2012 once install it is normally very stable i would suggest upgrading to the service
THOMAS-P
Message 5 of 6
Many Thanks
john46
Message 6 of 6
any time always glad to help 😉
