jackluhg
Message 1 of 8
Slow Fibre Speeds - dropped to 5Mbps
Hello guys
Recently noticed a drop in speeds with my home Broadband. Usually get around 30Mbps DS (on a FTTC line) although not the greatest it did the job, (don't think my profile is much above 45/50).
Currently getting around 4-5Mbps which is a pain in the ar*e. Checked BT website and no local faults... ran one speed test and it told me 5Mbps on a Fibre line is a 'Good' speed.
Ran a test on the DSL checker, see below.
Anyone know anything I can do to get speeds back to normal?? Don't really want to spend £130 on getting an engineer out! Reset HH5, tried connecting Ethernet cable etc.. still no luck Smiley Indifferent
Thanks in advance
7 REPLIES 7
SuperSajuuk
Message 2 of 8
Re: Slow Fibre Speeds - dropped to 5Mbps
Please edit that screenshot and remove the phone number. This is a publically viewable forum and I really doubt you want people making nuisance calls to you? 😄
Run the following speedtester: after the first test completes, click the Further Diagnostics button, enter your phone number into the first box and then post the results of the second test here.
http://speedtest.btwholesale.com
jackluhg
Message 3 of 8
Woops!! Thanks for the heads up.. changed and added output from the Wholesale Speed Test 🙂
imjolly
Message 4 of 8
If you have the hh5 can you go to troubleshooting then helpdesk and post 1-12
SuperSajuuk
Message 5 of 8
@jackluhg We need the results of the second test, not the first one. Also, your number is still visible in the first picture.
jackluhg
Message 6 of 8
Thanks for the help - here's the further diagnsotics results..
imjolly
Message 7 of 8
Can you post stats from you Router please
john46
Message 8 of 8
posts cannot be edited after 1 hour
