Message 11 of 18
Re: Slow Infinity Speeds!
Thanks for you response.
Do you need me to send you my phone number?
Here is another test at around 18.20
FAQ
Results Image not loaded
1. Best Effort Test:  -provides background information.
 Download Speed
 3.55 Mbps
0 Mbps53.18 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 3.55 Mbps
 For your connection, the acceptable range of speedsis 27.5 Mbps-53.18 Mbps .
 Additional Information:
 IP Profile for your line is - 53.18 Mbps
2. Upstream Test:  -provides background information.
 Upload Speed
 0.34 Mbps
0 Mbps10 Mbps
Upload speed achieved during the test was - 0.34Mbps
 Upstream Rate IP profile on your line is - 10 Mbps
This test was not conclusive and further testing is required.This might be useful for your Broadband Service Provider to investigate the fault.
If you wish to carry out further tests,please click on 'Continue' button.If not, please close the window using 'Exit' button and contact your ISP for further assistance with these results.
Message 12 of 18
@Masterplan If you fill in the click here to contact the mods link that @DanielS mentioned we'll be able to get this looked into. When you click the link it will request all the info we need.
Message 13 of 18
Thanks details sent.
Message 14 of 18
Hi @Masterplan I called earlier sorry I could not reach you.
I've run some checks and as Daniel advised there is no current records of congestion on your Svlan or any of them in your area. I've reported a fault to Wholesale on the back of your speed test results which you have completed and will check the progress of the fault and update you as soon as I hear back from them.
Cheers
John
Message 15 of 18
Speeds back to what it should be tonight.
FAQ
 Download Speed
 51.78 Mbps
0 Mbps53.18 Mbps
 Download speedachieved during the test was - 51.78 Mbps
 Upload Speed
 8.85 Mbps
0 Mbps10 Mbps
Upload speed achieved during the test was - 8.85Mbps
Message 16 of 18
Hi @Masterplan Thanks for posting back the update and good news to hear that the speeds are back to normal. 🙂
cheers
John
Message 17 of 18
Speedtest today at around 12.20pm.
Seems to be running ok for the last few days. Hopefully that,s the end of the slow speeds.
Thanks @JohnC2
FAQ
 Download Speed
 51.46 Mbps
0 Mbps53.18 Mbps
 Download speedachieved during the test was - 51.46 Mbps
 Upload Speed
 7.66 Mbps
0 Mbps10 Mbps
Upload speed achieved during the test was - 7.66Mbps
Message 18 of 18
I have another question relating to the BT Sport online player problem I am having.
I raised a thread in January asking why it it does not play on my PC but I did not get a reply from BT.
As you know I joined BT in December & began watching BT Sport online a few days after I joined without any problems then in January the problems started.
The player streams in SD for 5-10 seconds then stops & the picture goes into HD, then it freezes & stutters. It is unwatchable.
I am using the same PC on a wired connection as I was when I joined BT, all drivers & browsers are up to date. I have tried every browser out there but to no avail.
BT Sport is the ONLY website that I have streaming problems with so the problem lies with BT.
