Message 1 of 18
Slow Infinity Speeds!
I am currently receiving slow infinity speeds.
Below is the bt speedtest
FAQ
Results Image not loaded
1. Best Effort Test:  -provides background information.
 Download Speed
 3.46 Mbps
0 Mbps53.18 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 3.46 Mbps
 For your connection, the acceptable range of speedsis 27.5 Mbps-53.18 Mbps .
 Additional Information:
 IP Profile for your line is - 53.18 Mbps
2. Upstream Test:  -provides background information.
 Upload Speed
 0.37 Mbps
0 Mbps10 Mbps
Upload speed achieved during the test was - 0.37Mbps
 Upstream Rate IP profile on your line is - 10 Mbps
This is from my home hub 6
Product name:
BT Hub 6A
Serial number:
+084316+NQ73789102
Firmware version:
SG4B1000B522
Firmware updated:
24-Jan-2018
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
0 Days, 2 Hours 17 Minutes 25 Seconds
Data rate:
10.00 Mbps / 55.00 Mbps
Maximum data rate:
30724 / 124325
Noise margin:
23.1 dB / 27.8 dB
Line attenuation:
13.6 dB
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
71 MB Uploaded / 859 MB Downloaded
Any mods help please?
17 REPLIES 17
Message 2 of 18
Re: Slow Infinity Speeds!
Just to add that I have factory reset the hub today.
Message 3 of 18
Was the speedtest run using a computer connected to the home hub using an Ethernet cable, with no other devices connected to the home hub?
Which exchange are you connected to?
Message 4 of 18
speed is exceptionaly low  can you try running diagnostic test again with ethernet and using a different browser IE/Edge/chrome
Message 5 of 18
Thanks for your help.
I,m connected to my PC via an ethernet cable. No other devices are connected when testing.
Speed is up & down while doing multiple tests. Tested on different browsers.
My exchange is Ruabon, Nr Wrexham, North Wales.
Just logged into my account to see a broadband fault raised on the 29/1/18. It is saying the fault is at BT retail servers.
I raised a fault on the 10/1/18 about the BT sports online player stuttering & freezing. I started a thread here as well but I did not get a response from BT. It still doesn,t work now & I gave up chasing it up.
Message 6 of 18
Hi @Masterplan,
I've checked your exchange for you. There aren't any reported congestion issues.
Can you double check your number to make sure you are on that exchange?
You can do so here SamKnows - Telephone Exchange Search
DanielS
Message 7 of 18
Hi @DanielS,
100% certain that is my exchange.
It,s the only one in my area.
What is BT retail servers fault that is showing in my account?
Message 8 of 18
Another test tonight at 8.17pm
FAQ
 Download Speed
 3.51 Mbps
0 Mbps53.18 Mbps
 Download speedachieved during the test was - 3.51 Mbps
 Upload Speed
 0.33 Mbps
0 Mbps10 Mbps
Upload speed achieved during the test was - 0.33Mbps
Message 9 of 18
Do not do any more tests so that result is left on the server.
This is probably best left to a moderator to look more closely.
I will ask one to help again.
Message 10 of 18
It is possible that it's your exchange but from the check I ran there was nothing raised. BT Wholesale, our suppliers, are usually very good for spotting hot VLAN's or congestion. We'll need to test everything on our end to rule out everything else. We can always speak with our suppliers to see hot your VLAN, specific to your telephone number is performing. There are only 3 VLAN's for your exchange.
To get in touch with us, click on my user name and then on contact the mods. It may take us a few days to pick it up but we will do all we can to help you.
DanielS
