Message 1 of 4
Slow Internet Speed - Please help
When I was with Talk Talk my BB download speed was between 2000 - 2600 Mbs.
Now I am with BT my speed has slowed to around 1200 Mbs.
The router is plugged into my master socket & I’ve connected directly to the master plug in the socket.
Here are the stats from my router.
Thanks in advance
1. Product name:BT Home Hub
2. Serial number:+058720+1112016636
3. Firmware version:Software version 4.7.5.1.83.8.57.1.3 (Type A) Last updated 13/05/11
4. Board version:BT Home Hub 3.0A
5. ADSL uptime:3 days, 05:59:01
6. Bandwidth:448 / 1408
7. Data sent/received:0.1 / 1.5
8. Broadband username:bthomehub@btbroadband.com
9. BT FON:Yes
10. Wireless network/SSID:BTHub3-W7P7
11. Wireless connections:Enabled, (802.11 b/g/n (Recommended)) 20 MHz, WPS enabled
12. Wireless security:WPA and WPA2
13. Wireless channel:Automatic / 6
14. Firewall:Default
15. MAC Address:94:fe:f4:37:34:26
16. VPI/VCI:0 / 38
17. Line profile:Interleaved
18. Software variant:-
19. Boot loader:-
3 REPLIES 3
Message 2 of 4
Re: Slow Internet Speed - Please help
you need to post the adsl stats from your hub
modulation
attenuation
connection time
noise margin
power
 then seect show detail and post erors as well
also run btspeedtester and post the results
Message 3 of 4
Thanks imjolly:
ADSL Line Status
Connection Information
Line state:Connected
Connection time:3 days, 06:35:53
Downstream:1.375 Mbps
Upstream:448 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.1 Annex A
Latency type:Interleaved
Noise margin (Down/Up):14.7 dB / 14.0 dB
Line attenuation (Down/Up):52.7 dB / 31.5 dB
Output power (Down/Up):17.9 dBm / 11.9 dBm
FEC Events (Down/Up):5112 / 247
CRC Events (Down/Up):508 / 38
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):355 / 20
Error Seconds (Local/Remote):3261 / 64
Message 4 of 4
your noise margin is high at 14.7 as normal about 6
you are currently connected to the master socket but do you have extension sockets in other rooms in your home?  if yes and master looks like this  master socket.jpg  have you tried connecting to the test socket behind the bottom half.  this is your direct connection to the exchange and will eliminate any noise problems caused by your internal wiring
