Message 11 of 19
Re: Slow, Slow, Quick, Slow
Sorry for delay, but has returned true to form, sub 1mbps:
Message 12 of 19
What are your current ADSL stats, as I think I can see what the problem is?
Message 13 of 19
Hi thanks for the speedy reply:
ADSL Line Status
Connection Information
Line state:Connected
Connection time:0 days, 00:03:15
Downstream:6.023 Mbps
Upstream:1.019 Mbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.3 Annex A
Latency type:Fast
Noise margin (Down/Up):6.7 dB / 6.2 dB
Line attenuation (Down/Up):46.0 dB / 27.9 dB
Output power (Down/Up):19.5 dBm / 12.6 dBm
FEC Events (Down/Up):0 / 0
CRC Events (Down/Up):7240 / 45
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):6978 / 14
Error Seconds (Local/Remote):150 / 12
Message 14 of 19
I can see the problem, you need to get your latency set to interleaved and not fast, its the CRC errors that are causing the slowdown, assuming that you are still connected to the "test" socket on the master socket.
If you would like to contact one of the UK based BT Care Team who moderate this forum, they will be able to lock it to interleaved.
They can be contacted using this link BT Care Team
They normally respond by phone or e-mail, within three working days, however you should get an immediate confirmation, with a tracking number.
Message 15 of 19
Thanks for the response, i've emailed them and will update when and if it gets sorted.
Message 16 of 19
Ok please keep us posted
Message 17 of 19
Please keep the home hub plugged into the "test" socket, as that should eliminate any problems within your own wiring.
Message 18 of 19
Wow, got to say I'm impressed, less than 2 hours after emailing them from the advice receieved on here the problem is fixed.  It was the latency as suggested.  Massive thank you to everyone who helped and a big thanks to the BT Care Team who acted so promptly.
Message 19 of 19
You
It is quite easy for them to do and can be dealt with quickly as a few of them have access to the correct software tool.
When the change has taken place, your latency should show "Interleaved". You will see FEC events, but they are quite normal, and are correcting line errors. They do not affect your thoughput.
I am pleased that the were able to help quickly Smiley Happy
