Well
Just had a visit from openreach to find out why my broadband had dropped from 75 mb to 10 mb
Line ok to cab .....he found the exchange people had capped it at 10 mb
instead of contacting me just shut the line down
this all results from when the hub 6a got the 223e software and we got the 2 hr reboot
So with me trying the hub 6 then the hub 5 caused it to die
line now reset got to wait to resync
Back to Old Hub 5
of the TP-link which would be the best to buy to get away from the BT routers
Depends on your budget and requirements. The VR600 is a reasonably priced middle specced device.
@prinknashof this parish is happy with his. I have the TD-W9980 but would no longer recommend it as it is getting a bit long in the tooth and there is doubt over IPv6 firmware availability
Yes, very happy with my VR600. I've had it running for two months now and it's done everything I've wanted it to do without requiring any attention. (Compare and contrast the behaviour of the HH6!)
Native IPv6 does work with devices connected to the VR600 but the implementation is a bit clunky in the current firmware. TP-Link are, however, working on new firmware to put that right.
p
Ok thanks
Will have a look soon after line has resynced
BT Hubs used to be good until the played with the software like the hub 6a
made it into a usless unit
I forgot to add
Was made aware that Fibre Boadband is not a friendly as the old adsl
where the adsl would cope with resyncs like the hib6 has been doing it would just resync no problems
the new Vdsl cannot cope so well it will not resynce so well that it could just keep resyncing and die
I have just found that out my hub 6 with the 223e started he big drop one started i tried the hub5 it kept going
ended up with 10mb download with 1 mb upload
instead of wholesale resycing as they can see what router i was using just capped it at 10mb
openreach eng had to ASK to wholesale reset to start the resync again
Not a very good system
everyone bllaime openreach but most of the issues are whole sale
Hi All
Just managed to find out why my line was stuck at 43 mb speed
When the eng called to check my line he installed a new openreach face plate 5c
thought nothing of it but my speed after Wholesale capped it at 10mb due to the hib6a 223e software issues
broadband was reset after 10 days only got to 43 mb should be back to the max spped i had before
complain again to high level complaints
eng to call again ....then looked at new face plate discon it and stuck router into test socket
after router fired up well ip profile was at 77.35
it was the new face plate
my org one that he replaced did have any issues
so beware if you have had a new 5c face plate it could affect your speeds
this is the router now have not seen this since the dec 6th software update
DSL uptime:
0 Days, 4 Hours 11 Minutes 52 Seconds
Data rate:
20.00 kbps / 80.00 kbps
Maximum data rate:
19999 / 84486
Noise margin:
15.1 / 7.3
Line attenuation:
15.9
Be aware that you could be charged £130 for the engineer replacing the faceplate. The second one should be free under "warranty" but the first one could be charged.
Have not replaced it just plugged into the test socket
awaiting high level complaints to contact me as advised them what had done and found.
24 hrs no issues so far
Managed to get visit cancelled
will leave router in Test socket for sometime now before putting the face plate that was working back on
DSL uptime:
1 Days, 1 Hours 1 Minutes 24 Seconds
Data rate:
Maximum data rate:
19999 / 84486
Noise margin:
15.8 / 7.6
Line attenuation:
15.9
so long as bt do not screw up any other updates like the 223e for the hub 6
