Message 21 of 27
Re: Slow Upload / ADSL 2+ Unavailable
Or a fault with the filter
Nihil
Message 22 of 27
Ok, so I took your advice. I've now swapped out the microfilter with a new ADSL nation XF-1e, tried new cables just in case any of them were damaged and also replaced my phones (my previous ones were pretty old anyway).
I've been connected to the test socket just in case my extensions are at fault, which doesn't seem to have made a difference. Still have one phone base station connected to the microfilter, but disconnecting it doesn't seem to help either.
My connection dropped for around 4 minutes at 9.30 this morning (the phones weren't in use), dropped three times between 7.22 and 7.30, once a little past midnight and five times between 21.30 and 22.30 last night. Some of the drops seem to last for minutes, most just reconnect straight away.
Current connection details are below:
Upstream:
Noise Margin: 5.0 dB
Connection Rate: 64 Kbps
Line Attenuation: 31.5 dB
Power: 10.6 dBm
Max Rate: 176 Kbps
SuperFrames: 318249
SF (CRC) Errors: 284
Reed Solomon: 1352056
RS Corrected: 2700
RS Un-Corrected: 0
HEC: 152
Errored Seconds: 0
Severe ES: 0
Interleave Depth: 2
Bitswaps: 1791
Downstream:
Noise Margin: 11.3 dB
Connection Rate: 1600 Kbps
Line Attenuation: 61.0 dB
Power: 17.3 dBm
Max Rate: 1856 Kbps
SuperFrames: 319425
SF (CRC) Errors: 3
Reed Solomon: 5430217
RS Corrected: 351
RS Un-Corrected: 22
HEC: 12
Errored Seconds: 123
Severe ES: 83
Interleave Depth: 8
Bitswaps: 47
Message 23 of 27
You need the forum mods help with this one they will post here when they read your post with a contact link for you to use
Moderator
Moderator
Message 24 of 27
Hi Nihil,
Thanks for posting. I'll look into this for you. Drop me an email with the details. You'll find the "contact us" form in the about me section of my profile.
Cheers
David
Nihil
Message 25 of 27
Thanks, I've just submitted an email via the contact us section. Also tried contacting BT customer support via phone.
Arranged a callback for today, was called by someone who told me "the connection appears to have been stable for the last 24 hours. Lol, not quite sure what their idea of stable is.
Apparently they'll monitor it again another 48 hours, and arrange yet another call back. I think their exact words were "now you're connected to the test socket". After telling them I've been connected to the test socket for over a week Smiley Very Happy
Message 26 of 27
just leave it to the forum mods now as contacting the help line will now only cause confusion
Message 27 of 27
I agree in that I would leave the mods to deal with it and avoid CS now
