Lost my landline for a couple of days last week however my Infinity soldiered on, although a bit slower than usual. 4 days later & my speed is still stuck at around 60mbps down 13mbps up with a ping time twice what it was. Until the fault occured I was at full speed in both directions, not suprising as the cabinet is only a few metres away from my house. When I mentioned that the speed hadn't gone back up to the engineer who repaired the landline he told me to ring Bt & inform them that the landline was now fixed & they would do a reset.
IF ONLY! First call - we cannot help you for 24 hours after a repair as it might clear by itself - it didn't, next day - wasted my time running tests & totally ignoring what I was telling him, eventually decided he would have to refer it upstairs, heard nothing since. This is no way to run a buisiness!
My contract is up in March & by coincidence Virgin are about to finish the cabling of my area which stopped when Telewest went bust, could it be kismet!
In what way was his info. incorrect?
He told me I needed to contact the broadband support guys to get the line reset, and that's what I did.
Trouble is they seem to be more interested in spending their time fobbing me off rather than doing their jobs.
4 weeks is an unacceptable delay when everyone knows that doing the reset is possible and will fix the problem in a few minutes, not weeks!
normally a DLM reset is only done by an openreach broadband engineer during a visit to your home otherwise you just let DLM make the change automatically. just need to maintain a stable connection for DLM to take action to improve your conenction
@John25Roberts wrote:
After a line fault is fixed the DLM takes 3-10 days to stabilise. Although it may sometimes get stuck and need a manual reset.
You don't necessarily have to have an Engineer come do it, no reason why your ISP can't get the Openreach Support Team to do it.
The reason the Engineer who fixed the fault wouldn't have done it is because to do it you need a unique ref num to force a reset and that is only supplied to them on specific FTTC faults, not ordinary Voice Faults.
Except that Openreach won't allow it.
There is no reason why the ISP can't do it as they can with ADSL except Openreach won't allow it.
Can you see a pattern here?
@John25Roberts Openreach do not provide ISP's the facility to remotely reset the profile on FTTC connections. This can only be arranged by us sending an Openreach broadband boost engineer.
Neil
well in my experience and from forum post that doesn't happen
