wendigo30
Message 1 of 4
Slow broadband for 8 days
I have an open fault registered with BT about the slow broadband speed I've had( best speed 0.24 kbps, usual speed about 1.2Mb) for the last 8 days.  After the usual checks as directed by the call centre i.e. try the test socket, unplug all extensions, try the quiet line test I was told to wait for an answer while other checks were made.
Checking my fault on the bt website, no further communication has been forthcoming from BT.
So I left my router plugged in as always while I was away working for 4 days, came back and checked the speed again last night.  Again 0.24 kbps according to the bt speed test.
In case it was down to not being used I started to download a large file and left it running overnight.  There was no improvement in speed though it's sticking resolutely to 0.24 kbps.
Can I get some help?
Tags (1)
3 REPLIES 3
john46
Message 2 of 4
Re: Slow broadband for 8 days
Hi Welcome to the community forums
Here is a basic guide to getting help from the community members done by CL Keith Please read through the link posted http://forumhelp.dyndns.info/speed/first_steps.html
once you have posted the information asked for then the community members can help you more
if using a hub 4 locate these lines located in the hub logs
Lines should look like this
19:11:29, 07 Nov. (2290101.460000) DSL noise margin: 7.00 dB upstream, 6.10 dB downstream
19:11:29, 07 Nov. (2290101.390000) DSL line rate: 448 Kbps upstream, 288 Kbps downstream
Thank You
This is a customer to customer self help forum the only BT presence here are the forum moderators
wendigo30
Message 3 of 4
Thanks.
Here are my results:
I don't have a BT Home Hub I have another router, Netgear router DGND3700v2
ADSL stats from Netgear router DGND3700v2
System Up Time 144:58:27
Port     Status     TxPkts     RxPkts     Collisions     Tx B/s     Rx B/s     Up Time
WAN     PPPoA     299527     405111     0     3740     24643     01:46:43
LAN1     1000M/Full     6843083     6695617     0     176703     40286     04:05:54
LAN2     Link down
LAN3     Link down
LAN4     Link down
WLAN b/g/n     --     --     --     --     --     --     --
WLAN a/n     --     --     --     --     --     --     --
ADSL Link     Downstream     Upstream
Link Rate     288 Kbps     811 Kbps
Line Attenuation     60.0 dB     33.7 dB
Noise Margin     22.8 dB     6.5 dB
Speedtest results:
1. Best Effort Test: -provides background information.
    Download  Speed
    0.24 Mbps
0 Mbps    0.25 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 0.24 Mbps
 For your connection, the acceptable range of speeds is 0.1 Mbps-0.25 Mbps.
 IP Profile for your line is - 0.25 Mbps
2. Upstream Test: -provides background information.
    Upload Speed
    0.6 Mbps
0 Mbps    0.83 Mbps
Upload speed achieved during the test was - 0.6Mbps
 Additional Information:
 Upstream Rate IP profile on your line is - 0.83 Mbps
Quiet line test:
No hssing or cracking on the line
imjolly
Message 4 of 4
your connection time is just over an hour was that a manual reset or router dropping conenction?
at present you are in a banded profile due to all the resets and you need to maintan a stable connection 24/7 for 3/5 days and banding should release automatically   if you get 3+ days stable then repost your router stats and mods may help  http://www.plus.net/support/broadband/speed_guide/broadband_terminology.shtml
