Taffer
Message 1 of 4
Slow broadband problem
Hello,
My broadband is running very slow it should be about 7+mb but appears to be running at 0.25 to 1mb. assuming wired connection. This has been happening since Tuesday and no mention of linework anywhere. Please advise thanks
stats -
download speed 248kbps upload 763kbps
ADSL line status
Connection Information
Line stateConnected <script type="text/javascript"></script>
Connection time0 days, 03:46:02
Downstream8,839 Kbps
Upstream968 Kbps
ADSL Settings
VPI/VCI0/38
TypePPPoA
ModulationG.992.5 Annex A
Latency typeFast
Noise margin (Down/Up)6.5 dB / 5.0 dB
Line attenuation (Down/Up)38.8 dB / 18.7 dB
Output power (Down/Up)11.8 dBm / 1.8 dBm
3 REPLIES 3
Message 2 of 4
Re: Slow broadband problem
Hi it sounds like a low ip profile it should return to it's normal level if left with no hub restarts for 3/5 days if you can run the Bt speedtest. Speedtester.bt.com and post the result back here we can then advise further
Taffer
Message 3 of 4
Seems to be working now. Thanks
Message 4 of 4
Hi Taffer
Glad all seems ok now if you ever need any further help or advise please post back and someone will help you
Nice to get positive feedback Thanks
