Jipper
Message 1 of 3
Slow broadband speed
I have "enjoyed" BT broadband for nearly 3 months since switching from Virgin. I have a home hub 5 which achieves download speeds of 30+ but then the speed will drop below 5 until a reboot takes place. The help team have tried different formulas with the hub but the same problem occurs. I believed the smart wireless feature was meant to search for the best connection constantly! There is no fault with the line and I have performed a quiet test.
Is there a solution to the constant rebooting problem?
2 REPLIES 2
pippincp
Message 2 of 3
Re: Slow broadband speed
Turn smart wireless off. Download and install InSSider (it's free) and select the least congested channel based on other routers in your area.
Smart wireless is a PITA!
Jipper
Message 3 of 3
Thanks for the tip, I'll give it a go!
