MaximusPrime
Message 1 of 12
Slow connection, Home Hub 5 stats look wrong
Hii,
my DSL dropped from 2.6 to 2.2 so I upgraded to BT Faster broadband - FTTC, 2.8km copper to my house.
Eestimated speeds of 5-9Mb but getting under 5Mb.
Home Hub 5 stats:
4. Board version:BT Hub 5A
5. DSL uptime:3 days, 02:03:10
6. Data rate:1185 / 4627
7. Maximum data rate:1181 / 4108
8. Noise margin:6.4 / 8.0
9. Line attenuation:18.5 / 39.8
10. Signal attenuation:18.5 / 32.2
1. My Data Rate is higher than my Maximum Data Rate which is strange.
2. My downstream noise margin is higher than my upstream, should be the other way around?
3. My downstream noise margin seems to be high, I'd expect it to be close to 6db?
Broadband Availability stats:
According to the Speed v Attenuation graph here: http://www.increasebroadbandspeed.co.uk/graph-ADSL-speed-versus-line-loss-distance I should be getting under 10Mb for my Line Attenuation of 39.8db.
Any ideas of what's going on?
cheers
11 REPLIES 11
imjolly
Message 2 of 12
Re: Slow connection, Home Hub 5 stats look wrong
your connection speed is just below the estimated minimum of 4.7mb but if you could get noise margin down to 6db then that should increase your speed to within estimate
was it self install?  if so are you using the test socket with a new filter?  if not can you try test socket
MaximusPrime
Message 3 of 12
Hi ,
an Engineer isntalled, fitted an MK3 Openreach faceplate, tested the line, all clear, he said he would have expected a bit more speed from the line as well. Only installed Wednesday past.
Monitoring the downstream noise margin since install I can see it is aiming for a constant 9db, it dropped to 8db yesterday for a while. When it drops the speed drops to try & increase the noise margin back to 9db.
BT default target noise margin is 6db is it not? Can I ring BT & ask them to reset my target noise margin to 6db?
cheers
imjolly
Message 4 of 12
line resets are done but engineer visit is required - not like adsl where mods could instigate the change
your noise margin may fluctuate as will your attainable speed but your connection spee should remain constant unless your router drops connection
MaximusPrime
Message 5 of 12
OK, cheers, the Engineer goes to the cabinet not to my house though?
imjolly
Message 6 of 12
no you would need an engineer visit to your home for a line/connection problem and he could then if broadband engineer arrange a line reset  you will not get an engineer visit for just a reset
MaximusPrime
Message 7 of 12
I rang them, customer support tried to fob me off saying I am getting "around" 5Mb so it's OK, I said it wasn't.
He's going to ring back on Wednesday to see if the probem still exists.
Do you reckon my downstream noise margin will come down to 6db from 9db automatically or is it locked?
Any advice on how to get an engineer out to lower the margin if it doesn't come down itself?
imjolly
Message 8 of 12
if your connection is stable 24/7 and there is no line noise then the DLM will reduce noise margin down to normal 6db but that could take a few weeks
you would need to have a line fault to get broadband engineer and then he may reset your conenction  however if no fault found then you may well get charged the £129.99 callout fee
MaximusPrime
Message 9 of 12
Ok, cheers for the info, have to wait a month then probably 😞
MaximusPrime
Message 10 of 12
Rang BT told them about the slow connection
Gave me a ringback 2 days later, still slow
Explained I wanted my downstream Target SNR reduced to 6db
Got through to a Supervisor
He agreed & booked an Engineer for free,
Now getting over 5Mb so in Estimated speed range 🙂
