Message 1 of 12
Slow connection speed
Hi,
My router line status is attached below. Can anyone advise why the line speed is so slow. I live very close to the Vauxhall exchange in London which I would have thought should have a fast speed?
Thanks in advance,
Greg
ADSL Line Status
Connection Information
Line state: Connected
Connection time: 0 days, 00:56:03
Downstream: 5.125 Mbps
Upstream: 448 Kbps
ADSL Settings
VPI/VCI: 0/38
Type: PPPoA
Modulation: G.992.1 Annex A
Latency type: Fast
Noise margin (Down/Up): 6.1 dB / 16.0 dB
Line attenuation (Down/Up): 32.2 dB / 18.5 dB
Output power (Down/Up): 19.9 dBm / 12.3 dBm
FEC Events (Down/Up): 0 / 0
CRC Events (Down/Up): 3 / 127
Loss of Framing (Local/Remote): 0 / 0
Loss of Signal (Local/Remote): 0 / 0
Loss of Power (Local/Remote): 0 / 0
HEC Events (Down/Up): 2 / 0
Tags (3)
11 REPLIES 11
Message 2 of 12
Re: Slow connection speed
can you please run btspeedtester and post the results
is there a reason why your connection time is < 1hr?
Message 3 of 12
Hi,
The connection time is low because the line has just been reset to reduce the Noise Margin from 10db to 6db - however this has only increased the speed from 4MB to 5MB. It seems there's a more fundamental reason why the speeds so slow.
Speed test results are as follows :-
Download speed achieved during the test was - 3935 Kbps
 For your connection, the acceptable range of speeds  is 600-7150 Kbps.
 Additional Information:
 Your DSL Connection Rate :5248 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
 IP Profile for your line is - 4500 Kbps
Thanks,
Greg
Message 4 of 12
you are about 2.4km line length from the exchange and on a good line with no noise problems I would expect about 7.5mb connection.
have you tried connecting to the test socket to see if that helps as that is your direct connection to the exchange?
Message 5 of 12
Yes, it makes virtually no difference. The line is a brand new install when I switched to BT.
Tags (1)
Message 6 of 12
if you have no extension sockets in your home then using the test socket should make no difference.  your stats look ok just I would have expected a faster connection but your noise margin is ok suggesting there is no noise problem
Recognised Expert
Message 7 of 12
Looking at your exchange, you have availability for BT Infinity as well as ADSL2+, your currently on ADSL max, I would've thought that as its a new connection you would have been put on to ADSL2+? Imjolly?
Message 8 of 12
unless like a lot of london exchanges they are close to full so there may not have been and 21CN connections but I agree there is no harm in asking as it would really increase speed.  if infinity also available then I know what I would do - infinity for me
Message 9 of 12
Hi,
By 21CN I assume you mean BT's new network that offers ADSL2+. I was told that even without this there were both 8MB and 20MB transit for standard ADSL. Could you confirm if this makes sense. I was wondering what transit speeds are available through BT since they advertise 20MB?
Thanks,
Greg
Message 10 of 12
adslmax is up to 8mb and 21CN which is adsl2+ is up to 20mb.  infinity is up to 40mb
