Message 1 of 11
Slow connection
Hi
I've been getting 30+mbps up to August but the speed has now dropped over the past few weeks, see the speed test below.
I connect via cable and had a previous issue at the start of the year with speeds dropping which was successfully fixed by resetting my profile (I think).
Could someone take a look?
Jon
13479021054565237112
10 REPLIES 10
Distinguished Expert
Message 2 of 11
Re: Slow connection
wow thats slow
Message 3 of 11
Re: Slow connection
could you please post the full diagnostic BT Speedtest so we can see your IP Profile http://speedtester.bt.com/
Message 4 of 11
Re: Slow connection
I have noticed that site reporting low over the last few days maybe a server problem
Message 5 of 11
Re: Slow connection
John
I've done the quick BT test and that shows the same result. The more detailed one hangs on 'Now Testing your Upstream speed for:Test 1', with progress at 100%.
Jon
Message 6 of 11
Re: Slow connection
Could you just try the beta test and post that
Your speed is very low
Message 7 of 11
Re: Slow connection
I'm on a Mac and can't work out how to print the screen.
The results are -
Download 6.39
Upload 0.66
Ping 38.75
Message 8 of 11
Re: Slow connection
Hi
I am sorry to see you are having problems with your BT Service
I suggest you contact the forum mods they should be able to get this problem sorted for you this is a link to them http://bt.custhelp.com/app/contact_email/c/4951
They normally reply by email or phone directly to you within 3 working days they will take personal ownership of your problem until resolved and will keep you informed of progress
They are a UK based BT specialist team who have a good record at getting problems solved
This is a customer to customer self help forum the only BT presence here are the forum moderators
Message 9 of 11
Re: Slow connection
Thanks, just logged an issue now.
Message 10 of 11
Re: Slow connection
An engineer visited yesterday, found the problem was with the cable outside the house and resolved the issue. Normal speed has now resumed.
Jon
