john46
Message 11 of 36
Re: Slow connection
we really need to see those two lines from your hubs logs
imjolly
Message 12 of 36
Re: Slow connection
it may be one of the routers that the 2 stats line no longer appear
peterbrook279
Message 13 of 36
Re: Slow connection
Started working again last night after dialing a number on my landline phone (line was crackly).  Wasn't connecting again this morning until I again deialed my phone.
The filter's plugged into the test socket.
I've found those lines at last:
12:34:54, 03 May.( 229.440000) DSL noise margin: 6.00 dB upstream, 6.80 dB downstream
12:34:53, 03 May.( 228.510000) DSL line rate: 312 Kbps upstream, 568 Kbps downstream
Updated diagnostic test, it's even slower now:
1. Best Effort Test:  -provides background information.
 Download  Speed
 0.04 Mbps
0 Mbps0.5 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 0.04 Mbps
 For your connection, the acceptable range of speeds is 0.1 Mbps-0.5 Mbps.
 IP Profile for your line is - 0.5 Mbps
2. Upstream Test:  -provides background information.
 Upload Speed
 0.26 Mbps
0 Mbps0.83 Mbps
Upload speed achieved during the test was - 0.26Mbps
 Additional Information:
 Upstream Rate IP profile on your line is - 0.83 Mbps
This test was not conclusive and further testing is required.This might be useful for your Broadband Service Provider to investigate the fault.
imjolly
Message 14 of 36
Re: Slow connection
You need to report a phone fault as there is a bad connection which is why you are getting connection after dialling a phone number
http://www.filesaveas.com/jarviser/hubtrouble.html#type9
peterbrook279
Message 15 of 36
Re: Slow connection
Do I report the phone fault to BT, even if BT aren't my line rental provider?  Is there a number I can ring?
imjolly
Message 16 of 36
Re: Slow connection
Who provides your phoneline and broadband?
imjolly
Message 17 of 36
Re: Slow connection
You never replied to say if using the test socket as that should be your best connection an eliminates the possibility of a faulty faceplate
peterbrook279
Message 18 of 36
Re: Slow connection
Line renal = Axis, broadband = BT.
Filter is connected to test socket.
imjolly
Message 19 of 36
Re: Slow connection
You need to report to Axis if they provide you phoneline/ line rental as this is a phone fault not a broadband fault
do you use a phone extension cable?
peterbrook279
Message 20 of 36
Re: Slow connection
I'd like to stress I've only had to ring my landline to get the broadband working since installing the new filter last night.
The fault with the slow connection existed before then.
