imjolly
Message 21 of 36
Re: Slow connection
Then did you try a new rj11 modem cable?  Connection should be test/filter/rj11/hub
peterbrook279
Message 22 of 36
Re: Slow connection
No, is a spare one provided in the box?
imjolly
Message 23 of 36
Re: Slow connection
No you only get one supplied
from looking back at older posts you had a 17mb connection speed so unless something has changed your current speed is very low suggesting a line problem which could easily also be a filter or cable problem
peterbrook279
Message 24 of 36
Re: Slow connection
So am I best ringing for technical assistance?
imjolly
Message 25 of 36
Re: Slow connection
you can try customer services but if the problem is internal then you wil get charged £129.99 for the callout hence why better to eliminate everything back to test socket so problem should then be outwith your home
peterbrook279
Message 26 of 36
Re: Slow connection
Yup I've tried a new filter, how do I get my hands on a new cable?
imjolly
Message 27 of 36
Re: Slow connection
you can buy one RJ11 (amaz0n) - good ones are shielded and look like this  belkin shielded rj11_.jpg
peterbrook279
Message 28 of 36
Re: Slow connection
Belkin 10m RJ11 Male to Male Hi-Speed Internet Modem Cable - White
Is this the right sort?
imjolly
Message 29 of 36
Re: Slow connection
that's an rj11 cable but not shielded.  I would post a link but not permitted on forum hence why I posted a pic
you can also try the auction site
peterbrook279
Message 30 of 36
Re: Slow connection
New RJ11 cable in place and no improvement in speed.
