Newbie
Message 1 of 4
Slow connection
Recently I start to got very slow connection 0.24Mbs download. My average connection was 4.75Mbs. I contacted BT about it and they send an Engineer to check phone line. Engineer told me that phone line is fine and possible problem can be with exchange or my broadband. He advise me to call BT once more and ask about reseting my broadband. I done what he said and nothing change.
Those are my broadband ADSL status:
ADSL Line Status
Connection information
Line state:Connected
Connection time:0 day, 02:06:06
Downstream:283 Kbps
Upstream:1,013 Kbps
  ADSL settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.5 Annex A
Latency type:Interleaved
Noise margin (Down/Up):11.6 dB / 5.8 dB
Line attenuation (Down/Up):48.0 dB / 27.3 dB
Output power (Down/Up):0.0 dBm / 12.8 dBm
FEC Events (Down/Up):1804 / 300
CRC Events (Down/Up):0 / 6
 I would be glad for fast respond.
3 REPLIES 3
Message 2 of 4
Re: Slow connection
Hi Welcome to the forums
Here is a basic guide to getting help from the community members done by CL Keith Please read through the link posted http://forumhelp.dyndns.info/speed/first_steps.html
once you have posted the information asked for then the community members can help you more
Thank You
This is a customer to customer self help forum the only BT presence here are the forum moderators
Newbie
Message 3 of 4
Re: Slow connection
thank you for the respond.
This is my result from speed test:
1. Best Effort Test:  -provides background information.
 Download  Speed
 0.07 Mbps
0 Mbps0.25 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 0.07 Mbps
 For your connection, the acceptable range of speeds is 0.1 Mbps-0.25 Mbps.
 IP Profile for your line is - 0.25 Mbps
2. Upstream Test:  -provides background information.
 Upload Speed
 0.67 Mbps
0 Mbps0.83 Mbps
Upload speed achieved during the test was - 0.67Mbps
 Additional Information:
 Upstream Rate IP profile on your line is - 0.83 Mbps
The test result has indicated that you should contact your ISP for further assistance.
And most current ASDL status:
ADSL Line Status
Connection time:0 day, 00:13:03
Downstream:283 Kbps
Upstream:1,016 Kbps
  ADSL settings
VPI/VCI:0/38
Type:PPPoA
Noise margin (Down/Up):11.6 dB / 5.7 dB
Line attenuation (Down/Up):47.5 dB / 27.3 dB
FEC Events (Down/Up):3 / 33
CRC Events (Down/Up):0 / 2
I cannot check if i hear any noise through my line becouse i dont have any phone set. I also still thing that problem is between my home and exchange line.
Message 4 of 4
Re: Slow connection
it could be a noisy line that is causing the problem you really need to eliminate it by connecting a phone to the test socket as this will also eliminate any possible charges (130.00) if an Openreach engineers visit and the fault is within your home is needed could you just borrow a phone from a friend or neighbour for the test
